Nothing works when in ACC. Ignition problem?
Old 14 Dec 2010, 02:46 pm
Default Nothing works when in ACC. Ignition problem?
I noticed my radio not turning on a while back when i turned the key backwards into the acc position. To test, i tried to use the cigarette lighter which should work when in acc, it didn't work. Could this be a problem with the ignition switch itself?
Old 14 Dec 2010, 04:20 pm
Default Re: Nothing works when in ACC. Ignition problem?
Why are you asking the same question that you did back on the beginning of December?
Radio won't turn on when ignition is set to acc
Old 14 Dec 2010, 09:05 pm
Because I haven't found the cause of the problem, and since it doesn't really have anything to do with sound and security and that board isn't very active, I figured i'd ask here since people frequent the general section and I might get some input. Sorry
Old 14 Dec 2010, 09:29 pm
It's the same forum. The same people go all over the forum answering questions. No different answers here than you'd get over there.
Ignition coil problem...maybe? pcm2a Tech & Performance Forum 26 22 Nov 2016 02:11 am
Ignition coil problem? Donna General PT Cruiser Discussions 21 24 Nov 2014 12:51 pm
Ignition Switch Problem? jjensen101 General PT Cruiser Discussions 8 11 Apr 2013 07:15 pm
new pt in the works for me Lynx42 General PT Cruiser Discussions 24 18 Aug 2009 03:44 pm
Possible Ignition Problem joeyj Tech & Performance Forum 1 01 Jun 2009 09:35 pm
