MPG drop in winter
Old 17 Dec 2010, 11:06 pm
edb edb is offline
Default MPG drop in winter
I have a 2003 PT limited edition, this is its first winter with me. My pt was doing 20-21mpg before December; but in December, after temperature drops significantly, it was doing 16-17 mpg.
That's more than 20% drop. Is this normal?
Old 18 Dec 2010, 04:59 am
Default Re: MPG drop in winter
My winterbeater has gone from averaging 30mpg for the three weeks prior to our snowfall, to an average of 26mpg since snow has moved in.
Do you have snow or just cold temps, and have you switched car over to snow/ice tires from all seasons?
Old 18 Dec 2010, 10:15 am
What you are seeing is the effect of the computer enrichening the fuel mixture and increasing the idle to compensate for the cold weather. Older cars had a choke on the carb that set when you stepped down on the throttle and gradually reset as the engine warmed up and if you have been around a long time like myself you drove cars that you actually pulled a mechanical choke lever on or under the dash to set the choke. As long as the weather is cold you are going to notice a decrease in mileage but it's perfectly normal. It's a bulletproof system and works very well.
Old 18 Dec 2010, 11:16 am
Also, the gas companies change their mixture in the winter time which results in lower gas mileage.
What’s the difference between summer-blend gasoline and winter-blend gasoline? - Ask.cars.com
Old 18 Dec 2010, 12:02 pm
mityqwik's Avatar
Exclamation Re: MPG drop in winter
all year long i had been doing around 23-24 mpg and this month its droped i knew something was causing this to happen and remember what crewzin just stated, there fuel mix really sucks
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 18 Dec 2010, 08:11 pm
BladeRunner's Avatar
I don't know if it's the same South of the border,but, up here right on the gas pumps it states."volume corrected to 15C" or something very close to that,so in winter they get away with selling a bit less than you pay for. That's the way I see it anyway..
Old 19 Dec 2010, 03:14 am
Do not forget that people leave vehicles running 10 to 15 minutes or longer to warm up before driving.
MPG Drop jbcrzn General PT Cruiser Discussions 15 24 Jun 2010 10:30 am
Drop it like it's HOT 808 Wheels, Tires, Suspension 48 03 Sep 2009 02:11 pm
K&N Drop in filter KingKole02 Tech & Performance Forum 27 01 Jul 2005 07:38 am
K&N drop in mcruz Turbo Wheels/Suspension/Handling 2 13 May 2004 10:11 pm
Drop-In K&N Filter CHROMEDCRUISER Tech & Performance Forum 8 04 Jan 2004 02:06 am
