How to convert video with high quality of sound and image ?(a fantasy video converter
Old 18 Dec 2010, 10:00 pm
Default How to convert video with high quality of sound and image ?(a fantasy video converter
Are you a movie fanatic? Do you still worry about how to convert videos because you are Mac user? Here is a ginormously powerful tool to combine these two wonderful things. With 4Videosoft Video Converter Platinum and 4videosoft Video Converter for Mac, you can convert your own favorite movies to all your portable devices.
This step by step guide introduces to you 4Videosoft Video Converter Platinum and Video Converter for Mac to convert video files from one format to another. It can convert those videos to MP3, MP4, 3GP etc format, as well as convert them to iPod, iPhone, PSP etc popular portable player for your Playability watching on them. In a few clicks, everything is set for you.
What you need?
Windows NT4/2000/2003/XP and Windows Vista
Mac OS X v10.4 - 10.5
800MHz Intel or AMD CPU, or above; 512MB RAM or more
Part One: How to convert Video in an easiest and common way(for windows users)
Step 1: Download 4Videosoft Video Converter Platinum , install and run it.
Step 2: Click “Add File” to add Video from your computer.
Double click this video converter, then will start to experience this powerful video converter.
(1) Add: Add the video files.
Click the to add what you want to convert video files.
The supporting input format including:
(2) Profile: Choose the output format from the "Profile” Column, find what your player supporting format or the devices.
The output format is also powerful, you can see from the following picture.
(3) Settings: Click "Settings” to open the settings window.
(4) Merge: You also can put you file into one, just click” Merge into one file”, that’s ok.
(5) Destination: Click the "Browse”, you can put the converted file into what you want disk, and in the "Open Folder”, you can find the file
There are also powerful functions such as “Effect”, “Trim”, “Crop” .
Step 3: Start conversion
Click the "START” to convert your file. It will be finished in a little time.
Part Two: How to convert Video in an easiest and common way(for Mac users)
Step 1: Download and install 4Videosoft Video Converter for Mac.
Step 2: Add Video files.
Click the "Add Files" button to add video files to the program by automatically selecting an appropriate encoder for the video files you want to convert
Step 3: Edit your videos.
1: Video Effecting
Click the “Effect” button and a dialog pops up, you can set your video effect here.
Brightness: Drag and click the Brightness adjustment bar to set the brightness of the video.
Contrast: Drag and click the Contrast adjustment bar to set the contrast of the video.
Saturation: Drag and click the Saturation adjustment bar to set the saturation of the video.
2: Crop video
There are two methods available to crop your video:
Method 1: Crop by selecting a crop mode
Select a crop mode in the Crop Mode drop-down list and click OK to save the crop. There are seven pre-set crop modes for your choice: No Crop, Cut off Top and Bottom black edges, Cut off Top black edge, Cut off Bottom black edge, Cut off Left and Right black edges, Cut off All black edges and Custom. For "Custom", it allows you to customize your movie according to your needs. To crop your movie video, you can just drag your mouse cursor from four sides and four angles.
Method 2: Crop by setting the crop values
There are four crop values on the lower right part of the crop window: Top, Bottom, Left and Right. You can set each value to crop your movie video, and the crop frame will move accordingly.
3: Trim you video
Click the “Trim” button and a dialog pops up.
Set Start Time
Enter the start time in the Start Time box and click OK or drag slider bar under the Preview window and start time will be shown in the Start Time box for your reference.
Set End Time
Enter the end time in the Set End Time box and click OK or drag slider bar under the Preview window and the end time will be shown in the Set End Time box for your reference.
Step 4: Click the “START” button to start the conversion. You can have a cup of coffee or have a walk. In a quite short time it will finish.
Now for all users (Windows/Mac) you can enjoy your favorite Videos anywhere anytime.
Have fun! Enjoy yourself.
iPod+iPhone Mate
iPod Video Converter
DVD Ripper Platinum
DVD Slideshow Builder
Tags
dvd ripper, mts mac, video converter, video files on mac
