Inner tie rod ends on an '07 replaceable?
Old 26 Dec 2010, 07:02 pm
2007's Avatar
Default Inner tie rod ends on an '07 replaceable?
Are the inner tie rod ends replaceable on an '07 PT?
At just over 40,000 easy highway miles, it's had lower ball joints and control arm bushings replaced... now it need an inner tie rod end, but I'm not able to find a part online.
Old 27 Dec 2010, 01:38 pm
Default Re: Inner tie rod ends on an '07 replaceable?
The inner rods are removable and replaceable, but I can't find where Chrysler has them available seperate from the rack assembly. You may have to purchase the entire rack assembly.
There's a side note in the service manual anyway that states if you're unable to remove the rod from the rack that the entire rack must be replaced.
-Chris
Old 28 Dec 2010, 02:10 pm
[QUOTE=2007;334901].
i purchased a set of inner tie rods off of e-bay, don't remember the cost.
but after looking at the rack and pinion looks to me it needs to be removed before replacing the tie rods so i never installed them.
Old 28 Dec 2010, 05:26 pm
It doesn't need to be removed. The inner rods are completely removeable from the rack, but there's a chance that they will be seized on, in which case the entire rack must be replaced.
-Chris
Old 14 Jan 2011, 01:48 am
You can buy them off the internet all over the place. I'm not sure which one are the better ones out of the bunch but I found these on the
Energy Suspension web site.
MOOG MOOG-ES3173RL Front Outer Tie Rod End
Old 14 Jan 2011, 10:52 pm
UptownSport's Avatar
The inner?
Moog MOOG Part # EV404 UP to 2006
See Rockauto.com
I'd bet $5 it fits the '07; the aftermarket rack # is the same.
Mopar never sells inners, although they're (nearly) always available aftermarket.
The '95 only Neon came with a manual rack, you needed to find one from an
Omni to service, it's EXACTLY the same part- Listings for this component
required some guesswork.
The end appears to be chemically locked; the photo shows a tube
of chemical locker (Loctite).
Traditionally they are secured by 'staking' or a small screw (ford)
You can use a Crescent wrench or a pipe wrench. They make a special socket, but $$.
Old 14 Jan 2011, 11:55 pm
WolfmanG's Avatar
Originally Posted by UptownSport View Post
The inner?
See Rockauto.com
way to go Uptown. Damn dude you know your sh*t.
-Danny Wolfman G
Old 15 Jan 2011, 10:43 am
Don't forget the tool. It's essential. I have one I will sell to whomever needs it.
Amazon.com: Lisle 46600 Inner Tie Rod Tool: Automotive
Just a couple of odds and ends. Candyman Exterior Accessories Forum 10 25 Feb 2010 08:07 am
A few odds and ends: Candyman Classifieds: For Sale/Trade 6 06 Sep 2009 08:32 am
tie rod ends help musicmanchuck4 Wheels, Tires, Suspension 0 14 Apr 2009 12:52 pm
XENON front ends? 1lowufo Exterior Accessories Forum 3 09 Jan 2005 11:09 am
tie rod ends Swngdncr General PT Cruiser Discussions 6 05 Mar 2004 12:33 am
