check engine light
Old 29 Dec 2010, 06:32 pm
Default check engine light
sometimes it's on at start up, sometimes it's off.
sometimes it goes off while driving or on while driving.
a mechanic told me it's not showing any 4 digit code and that maybe the computer itself needs replacing.($600.00)
anyone heard of this before?
Old 29 Dec 2010, 06:37 pm
SCBluePT's Avatar
Default Re: check engine light
Are you having any other problems with the car?
Old 29 Dec 2010, 09:52 pm
nothing.
it's great in every way... except that.
i had the bushings replaced when i bought it and seriously love the thing.
except that little yellow light.
Old 29 Dec 2010, 11:11 pm
SCBluePT's Avatar
You can take it to Advance Auto or Auto Zone and they will scan it for free.I wouldnt go replacing the computer because it "may be" bad.
Old 30 Dec 2010, 06:37 am
You can also try taking off the negative battery cable for about 10 minutes. That might help be re-setting the computer. Can't hurt.
Old 30 Dec 2010, 01:12 pm
i'll give it a try.
Old 31 Dec 2010, 03:32 am
urimashe's Avatar
how cold is it? i find it turns on for me if its cold... around 18-25 degrees F it triggers the light, any warmer then that or any colder and it dosent trigger my light....
2006 Base PT Manual Tranny, K&N drop in filter, Marine Blue paint, Name: Blue Monster, Body style: Path Cruizer... oh yea, seat covers? got em.
Old 31 Dec 2010, 11:01 am
i live in Vancouver so it doesn't get too cold.
today is 22F (-5C) and the light is off...
Old 31 Dec 2010, 02:42 pm
Simple and silly question - when's the last time you changed your oil? Have you checked your oil level? This oil tends to "retract" upon itself when cold and then expand when heated, along with losing viscosity. My car is a southern car, meaning it doesn't get too cold here. However, this has been one of the coldest December's on the record books and for about three days it was below 20F. My check engine light would stay on longer each day, meaning when I started it up, all the lights lit up as usual, then the check engine one stayed on longer than normal. On the third day I took it to a friend's garage where I could get it indoors (it was snowing out) and check the oil level. Sure nuff, it was just above the fill line when cold. I dropped in about half a quart and haven't seen the problem since, that was two weeks ago and we've had even colder days since.
Just a suggestion.
i'll check that.
thanks for the suggestions guys.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
MIL (check engine light) without a DTC golfkell General PT Cruiser Discussions 5 09 Mar 2010 11:20 am
Is this check engine light? shester419 Tech & Performance Forum 3 22 May 2008 06:06 pm
Check Engine Light CHROMEDCRUISER General PT Cruiser Discussions 6 23 Jun 2004 04:58 pm
CHECK ENGINE LIGHT MEXICANPT Stage Turbo Kits 3 08 Aug 2003 11:13 am
