Trailer Wiring Harness Problem
Old 01 Jan 2011, 03:15 pm
Default Trailer Wiring Harness Problem
I had a trailer hitch installed on my 2004 PT Turbo, and I noticed the other day that I have continuous power going to my plug. I noticed this when I plugged in a hitch cover that lights up, and it had power to it and was on before I even turned my lights on from the car.
They ran a power wire all the way up to the battery, which I need to remove and run the power wire into the tail light wires,so it will only have power while the car's lights are actually on, so my question is, does anyone know which wire it is?
Old 01 Jan 2011, 03:26 pm
Default Re: Trailer Wiring Harness Problem
The tail lights are easy enough to take off, one screw. Then you slide the light up and out. Here's the wiring diagram for the lights. You can pick the correct wire that is hot for the running light and splice into it.
Old 02 Jan 2011, 09:49 pm
Thanks for the info Crewzin!
Old 11 Jan 2012, 01:28 pm
Can either of you let me know how that turned out? My understanding is that newer vehicles with oodles of computers/modules use very low amperage to vehicle lighting. Tapping into the wiring on new cars like we did in the past on old cars (pre-'96 I'd say) would cause problems to the vehicle's circuits/wiring. Hence the battery tap and wiring back to the converter. It supplies power to the trailer lighting, not the rear harness on the vehicle.
Old 11 Jan 2012, 06:11 pm
Actually you don't have to worry about loading your circuits pre-2006. It's in 2006 that they came out with the CAN buss, and that system is really a PITA to deal with.
Now, on my PT I had wired up for trailer lights even though I've not got a hitch yet. When I get enough money I'm going to buy a PT Trailer I think but may end up getting an AST trailer so I can drag my bike around with me.
What I did for my wiring was run a hot lead from the battery to the area in the trunk covered by the plastic near the fender well (inside the trunk). I have a simple relay bolted in there and grounded. Hot lead to one side, then the switched side goes to the turn signal wires for the tail lights. One on each side, just spliced the other side into the single hot line in parallel, and the turn signal indicators and brake lamps control the relay switching. Fairly easy job, takes a bit of wire but not that big of a deal.
I had all my stuff originally wired in directly, without using the relays, and one night while driving through Indianapolis, I got pulled over for no tail lights. The load burned out my MFS, so after getting it replaced I redid my wiring and now everything runs through relays, even my horns!
wiring harness? PTcruzer02 General Turbo Discussions 1 26 Jul 2009 06:08 pm
PT cruiser trailer wiring harness Samson General PT Cruiser Discussions 1 23 Apr 2009 09:26 pm
trailer wiring harness bonnie1943 General PT Cruiser Discussions 0 05 May 2008 11:05 am
PT Cruiser Trailer Hitch and wiring harness skinnyside Classifieds: For Sale/Trade 2 13 Dec 2007 09:56 pm
