Fluid for auto trans oil cooler
Old 01 Jan 2011, 05:42 pm
Default Fluid for auto trans oil cooler
I need to replace my radiator in my '01 Cruiser Touring, non-turbo, and was wondering if it is just regular coolant that runs through the transmission oil cooler, or if it is some other fluid. Thanks for the help!!
Old 01 Jan 2011, 06:36 pm
Default Re: Fluid for auto trans oil cooler
It's the regular coolant that runs through the engine and the radiator but saying that, it's not quite regular. Chrysler only recommends coolant that has HOAT properties. It's a special rust inhibitor so look on the label on anything you pick but make sure it says HOAT on it. There's a few different brands that have the HOAT properties such as Zerex and supposedly they be picked up at NAPA and other auto stores.
Old 01 Jan 2011, 08:45 pm
Sounds good, thanks CREWZIN!!
Another Radiator/Trans cooler question? mjb457 General PT Cruiser Discussions 5 17 May 2009 08:52 pm
Auto transmission cooler MINIHEMI46 Turbo Performance 22 16 Feb 2008 12:03 pm
TRANS FLUID DARK270 General Turbo Discussions 10 31 Jan 2005 05:29 pm
Trans Cooler? BB General Turbo Discussions 2 05 Jul 2004 07:57 pm
ATF+4 auto trans fluid finally available MX-5 Tech & Performance Forum 3 04 Sep 2003 01:20 am
