Dash light not working..
Old 02 Jan 2011, 12:46 pm
Default Dash light not working..
Thanks for the help with replacing the bulbs in my dash...
Another problem...I replaced all the bulbs, now none will work and the bright light indicator doesn't work ether!
I have taken the dash out 4 more times and I'm about to go nuts on why they don't work. The bulbs in the heater controls work but not in the speedometer cluster....
Old 02 Jan 2011, 01:56 pm
Default Re: Dash light not working..
The heater/air-conditioner part of the dash are a separate unit and should have nothing to do with the drivers cluster. If the drivers/dial cluster was working except for a couple bulbs before you took it apart to replace them and now nothing works, sorry but it's something you did with the cluster. You know about not turning the cluster upside down, right? Besides that, all it takes is one bad ground wire or something not connected to mes things up. Can't help you more than that. Good luck.
Old 02 Jan 2011, 07:12 pm
BladeRunner's Avatar
The cluster is a "self docking" type, if you don't pull it straight out and put it back straight you may bend some of the pins. Have a look at the connections...if you see any that are bent just gently straighten them.
Red light on dash pttroubles2 General PT Cruiser Discussions 9 16 Apr 2015 08:27 am
Showing ABS light, Brake light, Traction light on Dash fox50h Tech & Performance Forum 19 18 Feb 2014 11:40 pm
dome light switch on S/W not working outfit Interior Accessories Forum 0 13 Dec 2010 04:17 am
high brake light not working bobcatss66 General PT Cruiser Discussions 3 10 Mar 2009 01:32 pm
Gear Shift Light Not Working memejane Interior Accessories Forum 2 30 Nov 2007 07:55 am
