ABS sensor
Old 03 Jan 2011, 09:18 am
chuckd1991's Avatar
Default ABS sensor
I installed a new ABS sensor the other day, and the light is still on. Everything is connected properly. Someone said I should disconnect the battery and reset the computer. Any advice?
Old 04 Jan 2011, 06:38 am
Default Re: ABS sensor
By all means try diconnecting the battery.
How did you determine which sensor to replace?
o2 sensor peterock2002 Tech & Performance Forum 4 17 Oct 2010 12:21 pm
what is a MAP sensor? cruisergt General Turbo Discussions 18 27 May 2010 09:20 pm
Cam Sensor philski General PT Cruiser Discussions 1 20 May 2010 06:57 am
Cam Sensor code changed sensor still dead RottenKid Tech & Performance Forum 8 18 Nov 2008 08:17 am
F@#$%^ MAP Sensor!!! crazyjoe General Turbo Discussions 4 13 Nov 2003 10:01 pm
