changing tranny fluid
Old 09 Jan 2011, 12:56 pm
Default changing tranny fluid
I just wanted to know if its okay to have the transmission fluid changed if I haven't done it before. My PT has 100,000 miles and I'm its second owner. I dont know if the previous owner ever did it. Any opinions?
Old 09 Jan 2011, 01:44 pm
Default Re: changing tranny fluid
There seems to be two opinions on that. One is to leave everything alone since it's never been done and the other is to change it. I go along with changing it. Make sure you use ATF+4 fluid.
How about your timing belt. If it hasn't been done, your driving on borrowed time till it breaks.
Changing Transmission Fluid garyerrol Tech & Performance Forum 13 27 Jun 2016 05:02 pm
Changing transmission fluid and filter? tcnw05 Tech & Performance Forum 13 09 May 2015 10:14 pm
Antifreeze and Tranny Fluid? tbandab Tech & Performance Forum 2 28 Jun 2010 10:02 am
Overfilled tranny fluid Gamadonis Tech & Performance Forum 5 02 Mar 2010 08:09 am
Downshift problem after changing fluid and filter. spartanburgsc General PT Cruiser Discussions 3 24 Jun 2009 07:09 pm
