problem with driving lights
Old 09 Jan 2011, 10:33 pm
cllwyrc's Avatar
Default problem with driving lights
Since I have owned this car the driving lights have not worked. I have put new bulbs in checked fuses and all wiring looks good, is there anything I'm missing?
Old 09 Jan 2011, 10:42 pm
Default Re: problem with driving lights
hi i have heard a lot of the switch going bad
Old 09 Jan 2011, 10:54 pm
SCBluePT's Avatar
When you say driving lights are you talking about the fog lights?If so,are you pulling the end of the light switch out while the lights are on?
Old 10 Jan 2011, 12:27 am
cllwyrc's Avatar
Yes I was talking about fog lights. I didn't know you had to pull out on switch.
Old 10 Jan 2011, 08:10 am
SCBluePT's Avatar
Yes.once you turn your lights on pull outward on the end of the switch.Thats how you turn the fog lights on.
Old 10 Jan 2011, 08:18 am
...and a headlight (sort of) icon will light up on your dash.
Old 10 Jan 2011, 09:39 am
Have the same problem with my fog lights. Currently there is no fuse in my box for the fog lights. I found out why. When there is a fuse the fog lights will not turn off. So I have no fuse and no fog lights. Have you had a problem with your headlights not coming on? I get that from time to time, need to replace the controls I do believe.
Old 10 Jan 2011, 12:22 pm
cllwyrc's Avatar
No I don't have any problems with the head lights not turning on.
Old 10 Jan 2011, 01:36 pm
SCBluePT's Avatar
Were you able to turn the foglights on?
Old 10 Jan 2011, 04:21 pm
Monitor51, your problem is the multi-function switch (the stalk on the left side of the steering wheel). They go bad and when they do, the fog lights won't turn off. The previous owner was too cheap to buy a new stalk and just pulled the fuse. The new stalk will run anywhere from $75 to $100 and your problem with headlights and fog lights will go away.
2007 Driving Lights (Installation Problem) vinzchlortho Exterior Accessories Forum 3 30 Apr 2008 10:59 pm
IPF S630 Driving Lights? 1lowufo Exterior Accessories Forum 4 27 Feb 2005 01:07 pm
Driving lights question junkno General PT Cruiser Discussions 2 16 Aug 2004 09:10 am
After market Fog/Driving lights steve059 Tech & Performance Forum 2 16 Jun 2003 04:23 am
DRIVING LIGHTS MELTING Crash Exterior Accessories Forum 1 30 Nov 2001 03:06 pm
