2003 Pt Won't Start but has lights n sounds
Old 10 Jan 2011, 05:50 am
Default 2003 Pt Won't Start but has lights n sounds
I have a 2003 Pt Cruiser, auto trans. Drove it to work last night, no problems. Went to leave, put the key in, had lights and sounds, turned the key and nothing, no clicking, no humming, not a thing. The battery is 3 months old. This confuses me, am I looking at a starter or connection issues, it has been running like a top up till now, sucked having it towed home. Any ideas ??? Thanks so much !
Old 10 Jan 2011, 06:43 am
Default Re: 2003 Pt Won't Start but has lights n sounds
Check both ends of your cables, they can corrode internally .
Old 10 Jan 2011, 04:17 pm
Did you even try to jump start it from a good source, or just give up and have it towed?
Old 10 Jan 2011, 04:27 pm
cruserdad1976's Avatar
check the connections on the starter and I think there may be a fuse for the starter
Old 10 Jan 2011, 04:36 pm
There's no fuse for the starter itself but 2 in the PDC for "Ignition Start" and "Ignition Run".
Old 10 Jan 2011, 04:40 pm
Another question. You said you checked and had power to your lights. Were the fog lights on by any chance? Possible the multi-function switch went bad and left your fog lights on which would drain your battery in no time flat.
2001 PT Cruiser won't start, but radio and lights work alichi Tech & Performance Forum 15 26 Nov 2014 10:08 pm
Back Up lights come on in drive 2003 PT bbnjb3 General PT Cruiser Discussions 6 21 Mar 2013 04:09 pm
2003 interior lights stay on RLS7201 Interior Accessories Forum 7 13 Mar 2011 09:59 pm
2003 pt crusier wont start smith4384 General PT Cruiser Discussions 4 19 Jan 2009 02:27 pm
my 2003 pt makes a squilling noise on start up circe Tech & Performance Forum 8 09 Dec 2007 08:07 pm
