Front bearing/hub as assembly?
Old 15 Jan 2011, 10:41 am
Default Front bearing/hub as assembly?
Has anyone found a source for front hub with the bearing already installed? I need to do both my PT's soon and no access to a press most of the time when I'm actually able to work on the car. It would be so much easier if the fronts were sold as an assy.
Old 15 Jan 2011, 01:44 pm
UptownSport's Avatar
Default Re: Front bearing/hub as assembly?
You mean the entire knuckle?
Forget whatever I had posted here.
The hub is very easy to remove, it pounds out w/ a large socket.
Use a punch to remove the outer race, dremel to slice the inner race off hub.
(see far right hub ("95") in attachment, disregard labels)
You can make your own 'press' with threaded rod and large nuts/washers from McMaster Carr. Works very well, is more user friendly than a press, can be used in the field.
Old 08 Feb 2011, 10:23 am
I would LOVE to find the steering knuckle with bearing already in place. Man that would save so much time. Plus with practically nothing open on saturday...
Which wheel bearing/hub assembly do I need? Bonehead Wheels, Tires, Suspension 5 16 Aug 2010 11:19 am
Front Wheel Bearing/Hub Assembly Help UniSaitek Wheels, Tires, Suspension 1 28 Sep 2009 02:34 pm
Front Wheel Bearing?? mjb457 Tech & Performance Forum 3 12 Mar 2009 03:37 pm
How do you get the front bearing out of the HUB??? llcelebrity Tech & Performance Forum 5 10 Feb 2009 04:04 pm
front wheel bearing debspt Tech & Performance Forum 1 01 Oct 2006 11:42 am
