2006 pt cruiser touring help with fog lights and key
Old 17 Jan 2011, 02:44 pm
2006ptman's Avatar
Default 2006 pt cruiser touring help with fog lights and key
i'am new to the pt crusier,just put in my fog lights and they did not work ,but what i hear you have to go to the dealership ,i think that is a bunch bulljust to got fog light working but my biggest problem is with my key one minute the key was working then the minute it stop ,changed battery still no go ,i guess what i am asking does anyone know how to fix these problems without takeing it to the dealship ,thanks for any info you can give me
Old 17 Jan 2011, 02:50 pm
mityqwik's Avatar
Thumbs up Re: 2006 pt cruiser touring help with fog lights and key
i have an 06 touring that did not have fogs installed , if you installed the fog lights ,you also have to change your multi function switch the old one was not set up for fog lights and as i remember you have to have the stealership flash the computor for the fogs to work,as far as the key fob mine works sometime and some times not i give it a wack and it works,when it stops completly ill use the spare
It takes 8,460 bolts to assemble an automobile,
and one nut to scatter it all over the road
Old 17 Jan 2011, 03:12 pm
2006ptman's Avatar
Default Re: 2006 pt cruiser touring help with fog lights and key
the fog lights were already prewired ,and what does that mulfuntion swith look like and where does it go ,sorry if i'am acting so dumb but with this car i am
Old 17 Jan 2011, 03:21 pm
mityqwik's Avatar
mine came with the wires also this was an option that was offered in 06,the multifunction switch is your turn signal switch on the left side of the steering wheel if you have the fog light option on it ,,you would pull out on the end cap and turn it,i dont think you have that ,your other option would be to put in a switch somewhere on your dash to turn on the fog's
Old 17 Jan 2011, 03:52 pm
Pardon me for asking, but HOW did you try to turn them ON after you put them in ??? If you don't have the correct multi-function switch with the pull knob on the end as mityquik explained to you I'm curious to find how what you did ?? Pre-wiring means nothing as lot of cars come pre-wired for options that weren't added when the car was bought.
Old 17 Jan 2011, 03:56 pm
2006ptman's Avatar
i hooked the prewires up to the fog lights ,thats what though they were for
Old 17 Jan 2011, 04:10 pm
Send a message via AIM to slayerdarkcross Send a message via MSN to slayerdarkcross
Yeah I went through this situation actually...
I ordered the Mopar 06+ fog light kit which I only needed really half of what came with it as the wires were there. But you gotta have the dealership activate the fog lights which requires them to access the computer and what not. Ran me 100$ for the Mopar Kit and another 100$ to have my fog lights turned on.
Going to need that multifunction switch that pulls out though to use the fogs.
2006 PT Cruiser Touring Edition Reynolds1961 Tech & Performance Forum 3 04 Oct 2010 09:31 pm
2006 PT Cruiser Touring Edition zharrison07 General PT Cruiser Discussions 15 16 Feb 2010 10:16 am
2006 Touring, No Brake Lights cosmotcat Tech & Performance Forum 3 26 Sep 2008 07:19 pm
2006 Touring Edition - Lower lights never turn off EmeraldICE General PT Cruiser Discussions 7 12 Apr 2008 08:59 pm
