Some questions about rear disk brakes
Old 22 Jan 2011, 12:25 am
edb edb is offline
Default Some questions about rear disk brakes
I have a 03 Limited, bought it last year, and it has 22,600miles now.
The driver side rear brake was making noise because the pad on the outer board was completely gone. I just replaced the side and will work on the passenger side tomorrow, but I have a few questions since this is my first brake job, I am not sure if I am doing it right.
On the driver side, the inner pad still has a lot of life left, what caused the uneven wear? Is it the rust? There was heavy rust on the brake pad boards, the caliper adapter and the adapter abutment, and the caliper can hardly move. It took me quite a bit effort to remove it.
I put some brake lubricant on all contact points before installation, but how long will it last before rust comes back? I am in Michigan, steel develops rusts quick.
After installation, the caliper can freely move. Then I pump the brake pedal a few times, now both pads are in firm contact with the rotor. Is it what's supposed to be? Should the pads retract after brake pedal is released? or should they retract when the rotor moves?
I also noticed on the passenger side, the rear rotor has noticeably more wear than the driver side has. Is this because the previously uneven wear on the driver side reduces stopping power so that the passenger side had to work harder?
Sorry for some many questions.
Thank you for your help.
Old 22 Jan 2011, 04:39 am
UptownSport's Avatar
Default Re: Some questions about rear disk brakes
Originally Posted by edb View Post
The pads retract after brake pedal is released.
You are correct. Brake hoses degrade and plug, you can tell by cracking a bleeder when the brake is dragging,
There'll be a spurt.
If not, rebuild the caliper.
Otherwise, sounds like you did a good job on the abutments/Caliper.
Grease won't last long before it's washed off.
Old 22 Jan 2011, 06:42 am
WolfmanG's Avatar
ok so i'm totally confused. On my baby, she has rotors in the front and drums in the back. This is the 2nd post i read about a rotor being in the rear. So what's going on. do some models have like 3 rotors and 1 drum, or are they all rotors or is one side rotors and the other side drums? What the hell is going on? I'M LOSING MY EFING MIND HERE, AHHHHHHHHHH!!!!!!!!!:w acko:
-Danny Wolfman G
Old 22 Jan 2011, 06:46 am
SCBluePT's Avatar
Rear disk brakes were an option on the PT's up until 2010.They were standard on all 2010 models.
Old 22 Jan 2011, 09:32 am
twress's Avatar
He right on the option, my 01 LE had wheel disc brakes and my 02 LE Woody also has them too...an option you could have on your PT..it also has traction control in that option package also?
Hey edb where in Michigan are you??? I'm in Saginaw...
ROUNDIN UP THE WAGONS 02 LIMITED WOODY, 89 CAPRICE CLASSIC
Old 22 Jan 2011, 10:10 am
edb edb is offline
Metro Detroit.
Old 22 Jan 2011, 10:15 am
edb edb is offline
Thanks for your reply.
My visual check tells me the hoses are fine, but who knows. I am confused by "cracking a bleeder". What does that mean?
And I don't have to tools to rebuild a caliper, got to buy one. It's interesting that there is just no new caliper, all auto parts stores have rebuilt ones only.
Old 22 Jan 2011, 10:37 am
Cracking=just barely opening. Bleader's love to break off, so:
Get a six point socket or wrench (they make special bleeder wrenches)
Make sure the bleeder isn't plugged.
The hose exterior will look fine.
You could purchase new caliper from the dealer:
5083159AA $144.00
Brakes - Hydraulic system - Rear brakes - Caliper
Caliper, pt cruiser, left 2001 - 2010
5083158AA $145.00
Caliper, pt cruiser, right 2001 - 2010
Otherwise a rebuild is fine.
I've never rebuilt a rear caliper- Fronts are EZ and cheap to rebuild.
Old 22 Jan 2011, 02:47 pm
Matt42's Avatar
My 01 has rear disc brakes. My 04 has rear drum brakes. Both stop the car.
1996 Dodge diesel 4X4, 2001 PT Cruiser Touring with rear disc brakes, [Now gone 2004 PT Cruiser Base 5 speed], 2007 Chrysler T&C Touring
Old 22 Jan 2011, 07:39 pm
WolfmanG's Avatar
ok thanx for the info. i thought i was going crazy or something.
-Danny Wolfman G
Rear disk brakes on a PT? PTBoricua Tech & Performance Forum 10 23 Nov 2009 10:31 am
03 Factory Springs, 03 Factory in dash 6 disk head unit, Rear Shelf sill available: Candyman Classifieds: For Sale/Trade 3 19 Oct 2009 01:38 am
Front and rear disk brake upgrades for sale cruzzer-one Classifieds: For Sale/Trade 0 21 Jan 2008 09:56 am
F/S Rear Disk Brake Conversion latinkng Classifieds: For Sale/Trade 1 19 Apr 2007 02:31 pm
Turbo brakes - questions quicksilverdon General Turbo Discussions 4 01 Jun 2005 06:30 pm
