round edge oil drain plug
Old 23 Jan 2011, 12:39 am
edb edb is offline
Default round edge oil drain plug
I changed oil for my PT last August, everything was fine, and I did not overtight the plug. But this afternoon, when I tried to take it off, it was stuck. I remember it's a 13mm socket, but none of my sockets fits, any size, they are either too large or too small. Probably rust on it makes it grow bigger. So I tried an adjustable wrench and rounded the edge.
What should I do? I still want to do it myself, and don't like to bring it to a shop since I already have oil and filter ready at home.
Thank you in advance.
Old 23 Jan 2011, 12:47 am
SCBluePT's Avatar
Default Re: round edge oil drain plug
Well,if you rounded the head then I guess it is already ruined.If you can get a set of vise grips on it that should do the trick.Just make sure you clamp them down good and tight so they dont slip.Then get yourself a new drain plug to put back in it.
Old 23 Jan 2011, 01:51 pm
Always use a rachet wrench as they will not slip off and round the plug. When you get the bad plug off have a new plug ready to replace it.
Old 23 Jan 2011, 02:21 pm
UptownSport's Avatar
Originally Posted by 2004GTMAN View Post
Always use a ratchet wrench as they will not slip off and round the plug. When you get the bad plug off have a new plug ready to replace it.
QFT
Use six-point sockets/wrench. Craftsman/Snap-on/ non-Chinese (Nothing
against China, they make fine stuff I'm sure, just not for export)
Oil Drain Plug! Tech General PT Cruiser Discussions 9 19 Oct 2009 01:19 am
Oil drain plug AlmondTurbo General PT Cruiser Discussions 2 07 Feb 2007 04:54 pm
oil drain plug tagreen95354 Tech & Performance Forum 14 05 Feb 2006 09:37 pm
Oil drain plug valves gonzomania General PT Cruiser Discussions 6 28 Jul 2004 01:35 pm
Drain plug DREAM2 General Turbo Discussions 11 06 Jul 2004 10:14 am
