Rear Defroster
Old 26 Jan 2011, 01:59 am
Default Rear Defroster
My rear defroster mysteriously quit working, the heated mirrors are working fine. I checked the manual and can not find where the fuse for the rear defroster is.
2002 limited automatic.
Old 26 Jan 2011, 02:25 am
Default Re: Rear Defroster
Fuse #8 (40 amp green fuse) in the PDC (even though it's not marked for it) is part of that circut.
i got the above from a thread in november of last year. don't know if it solved his problem as he never responded after the fact. he also stated his heated mirrors were working.
Old 26 Jan 2011, 04:38 am
I just checked and fuse 8 controls both the rear defogger and the mirror defoggers. So if it blows both will quit working. There is a seperate fuse for the mirrors, but it is after the switch, so if it blows the the rear defogger will still work but the mirrors will not. A fuse cannot cause the rear defogger to not work, but the mirrors to still work, but it is possible for a fuse to cause the rear defogger to work but not the mirrors. The only thing that could cause the situation he describes is for the rear defogger element to go bad or to be scratched...or the ground to be bad for the rear defogger.
Old 14 Oct 2012, 02:08 pm
Mine had the same problem. All fuses were good. Pulled off the trim pieces around top and edges of the back window . . . Presto, the right side contact had come off the metal film. Did a tiny dab of hot glue and some duct tape to hold it while the glue set.
2002 ptcruiser Rear defroster cruiserworld General PT Cruiser Discussions 3 04 Nov 2010 01:08 pm
defroster problem ptjoe General PT Cruiser Discussions 0 04 Feb 2010 12:04 pm
2001 Limited defroster grille/vent/whatchamacallit redrider02 Interior Accessories Forum 13 03 Aug 2009 05:17 pm
Rough idle with A/C or defroster sawdust123 General Turbo Discussions 17 26 Jun 2007 03:00 pm
Rear window defroster leprecon7 General PT Cruiser Discussions 4 09 Jun 2004 10:40 pm
