Always warm air coming out of the vents!
Old 26 Jan 2011, 02:04 pm
ProDigit's Avatar
Default Always warm air coming out of the vents!
I changed my thermostat, because the prev user seemingly had removed it; and I noticed now that the engine runs hotter, that the air vents always 'blow' hot air.(when the fan or ac is set to 'off')
Not via fan, but more like outside air,
I tried to switch to closed air circulation (no outside air), and set the temperature to cold, but still get warm air coming in (fans are off).
I would agree if I set the right knob on the dashboard is set to outside air, that when driving some air would come in, but it seems I can not close the airflow of the vents.
Particularly annoying living in the South, and the summer's coming up (and I am not fond driving with the ac on),to continuously get engine heat (hand warm air) flowing in an already hot car.
What's going on?
Old 26 Jan 2011, 04:54 pm
Default Re: Always warm air coming out of the vents!
Since a few years ago all vehicles were designed for a flow of air when the car was moving. What you are describing is normal that is why you have vents in the rear door frame.
Old 26 Jan 2011, 05:06 pm
cruserdad1976's Avatar
dude you like in the south and dont run your air
Like already said im not sure you can STOP all the air from coming through i knwo on mine even with everything turmed off I can feel air now here where I like it is COLD air so maybe where you are it is just the flow through air that you are feeling
Old 26 Jan 2011, 10:52 pm
ProDigit's Avatar
Thanks for clearing that up guys!
Though, normally when you circulate the air inside, there should be no airflow.
Yeah, in the winter only (or any day when it's below 68 degrees in the mornings going to work, which happens about 40% of the year)
Old 27 Jan 2011, 01:37 am
Right now warm air coming out of vents feels pretty darned good!!!!
Old 27 Jan 2011, 10:48 am
it did in my ar today anyway
Old 27 Jan 2011, 03:17 pm
SCBluePT's Avatar
Neither one of our PT's has air coming from the vents when everything is turned off.
Old 27 Jan 2011, 05:28 pm
ProDigit's Avatar
Yeah, on mine it's only when driving and slightly warmer than outside air;so I figured maybe the air circulation/outside air knob is broken or something!
Old 27 Jan 2011, 06:05 pm
SCBluePT's Avatar
That's what I meant.When I am driving and the vents are turned off no air comes out of the vents on either one of our PT's.
Old 27 Jan 2011, 08:22 pm
03GTCruiser's Avatar
I met the air coming through, but when I switch to recirculating the flow stops 99% (still a little, but not noticeable.
I live just north of you in ft lauderdale, and in the summer, the air is not as warm as it feels now in our "winter"
Most of my heat is probably produced by the turbo motor (sitting at light with my arm out the window and a slight breeze I can feel the engine heat on my arm)
Sold 2003 Pt Cruiser GT Autostick. Sold
Now a slow 2009 Pontiac vibe 2.4l 5-speed.
http://www.ptcruiserlinks.com/forum/image.php?type=sigpic&userid=9656&dateline=1247691  818
227 HP and 281 TQ
new best of 14.56 1/4 mile on 7/25/12 still using the canned tune from my diablosport predator.
*Stage 1, DSP w/93 canned tune, 3" o2 housing, 3" FWDPerformance downpipe with cutout. Bwoody solid mounts. AMX1397 TTAB with K&n drop in filter and airbox mod. AMX1397 lower pipe and AMX1397 uppipe with HKS BOV
* stock nsrt rims powdercoated black, chrome pillars.
* 3 gauge pod w/ aem wideband, Autometer ultralite oil pressure and 30/30 boost, Mopar 8" sub.*
Gasoline Smell coming in Heater Vents 2002 PT Limited MarcusO Tech & Performance Forum 13 18 Jan 2016 01:05 pm
not getting warm air through the heater vents buztanut General PT Cruiser Discussions 5 20 Dec 2010 03:29 am
Air is blowing warm? enriquesoteloPT4 General PT Cruiser Discussions 2 21 Jun 2009 04:15 am
Warm A/C TaylorMade General PT Cruiser Discussions 5 12 Jul 2004 10:25 am
Warm Start issue? crazyjoe General Turbo Discussions 2 14 Feb 2004 05:31 am
