Heater core in o3 pt
Old 31 Jan 2011, 10:56 pm
Default Heater core in o3 pt
I have to replace the heater core in my 03 (I am a full time mechanic). I dont know exactly how to get to it and where it is located. Can anyone give some advice? Thanks so much BRYAN!!
Old 01 Feb 2011, 07:59 am
Default Re: Heater core in o3 pt
Hope these will help:
Old 02 Feb 2011, 04:52 am
Thanks so much. That is a perfect diagram. Looks a little harder than I thought!!
Old 02 Feb 2011, 09:24 am
Do you have a replacement? Reason I ask is I found two PT's in a yard nearby and am thinking of pulling parts from them.
Old 02 Feb 2011, 06:04 pm
UptownSport's Avatar
The heater core sucks so bad in Neon. I'd guess the PT is no better,
perhaps worse. Rockauto shows the same part number.
To get to the pictures you see above, you have to remove the entire dash and drop, perhaps remove, steer column.
I'd get the factory heater core, Rockauto sells it. (I'll edit in the brand name as soon as I recall it)
Good luck!!
Leaking Heater Core? chuck2112 Tech & Performance Forum 1 20 Nov 2010 04:39 pm
More heater core questions ddash General PT Cruiser Discussions 0 20 Sep 2010 02:23 pm
Heater core and rad replacement ddash General PT Cruiser Discussions 4 14 Sep 2010 06:35 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
anyone have the Core MBC?? magictrickboy71 Turbo Performance 3 20 Jun 2003 10:58 am
