I have a 2006 cruiser and everytime I turn the dial on for either heat or ac air it makes this one time bang noise. THen everything is fine, its just when I turn it on to get air. If anyone could help me on what this could be that would be great. Thank you.
i have an 2006 cruiser also and it makes the same noise and what Hooligan said it's the door opening to let air come thru your vents
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road |
Thank you somuch for the help. So this is normal then and won't cause any further issues?
Steph, I've had the same problem on my 2000 Mit. Mirage, as well as, my new Ford Ranger. It only seems to happen after I've not used the A/C for a few days. The PT doesn't do it--and we've had it since it was new in 2003.
It does not sound like a door opening to let the cool air pass. It sounds like something is being shook loose at the A/C compressor. Maybe it's the compressor clutch. It actually sounds like a part has rusted shut--and suddenly breaks loose. It only lasts for a second, then all is well. I drove my Mitsubishi Mirage for 8 years and the A/C did this if I didn't run it every day. I sold the car recently--and the A/C still worked as well as when the car was new. So I wouldn't worry too much about it. Tim |
Yes it only does it right when you turn the dial. It doesn't seem to affect anything but I just wanted to make sure it was not going to cause any problems.
My a/c isnt that great and doesn't seem to get as cold as it should but I was told that it probably just needs resetting. Is there a way to reset your ac without having to take it to a mechanic? |
Whoever told you it needs to be "reset", ask them what they are talking about. There's nothing to "reset". You might need to top off the R134 refrigerant but unless you know what your doing you could do more harm than good. Most A/C places will do a free check of your system. You don't have to buy anything you don't want to so try not to get talked into something you can't afford. Remember, your system IS running now, just not as cold as it should so it's probably a matter of topping it off. Don't let them tell you it needs a evacuation of the old stuff before topping off. It's a money maker if your just low.
Thread Tools | |
Display Modes | |
Foul smell when turn heater on 06 pt | kkrtype | General PT Cruiser Discussions | 8 | 03 Dec 2013 04:38 pm |
Heater Blower Motor Issue | sscanlan | General PT Cruiser Discussions | 5 | 30 Aug 2011 10:50 pm |
Turn Signal Issue-Please HELP!!! | 2002ptcruiserwoody723 | Exterior Accessories Forum | 1 | 28 Oct 2009 12:27 pm |
Block Heater, Rad Hose Heater, Which?? | kb0nly | Tech & Performance Forum | 13 | 23 Dec 2008 03:47 pm |
For imports only? (not dial up friendly) | OurPTGT | General PT Cruiser Discussions | 8 | 19 Dec 2003 06:20 pm |
