Door lock problems
  #21 (permalink)
Old 13 Jun 2013, 05:22 pm
Default Re: Door lock problems
i have no idea what that is. it's something aftermarket that i have never seen on any car. i would have to say it is the cause of your problem. i would take the dash top off and see what it's connected to. there might be a write-up on the procedure somewhere in the tech "how to" part of the forum.
randyincctx likes this.
2016 Kia Soul Plus Black
  #22 (permalink)
Old 14 Jun 2013, 03:01 am
Thanks for the info!
The other end of the cable goes into the same connector that connects on to the RKE module. The button itself has a LED on it, and if I remember correctly it used to blink (very low light) when the alarm was on. Also it sometimes blinks when I press the button itself. Could this thing be an extra receiver and of some sort which on a split signal interferes with the original receiver inside the RKE module somehow?
Thanks again, I will seriously get at it on this weekend..
  #23 (permalink)
Old 20 Jun 2013, 09:31 pm
randyincctx's Avatar
Exclamation Re: Door lock problems
Considering all the threads I've trolled through recently,this is probably going to be a dumb question;My 2003 PT has power door locks(all switches are there).....So,based on other threads I checked ALL the associated fuses(All OK!)......Today based on one of the threads I removed the dash to check the RKE Module.....But,where the RKE Module is supposed to be there is nothing but a plug with electrical tape over the 'pin holes' on the plug,and 3-4 black screws sticking out in the well for the RKE Module(See Photo)......My dumb question is this: Is this why my power door locks are not working????.......(In reality;The only dumb questionis the one you don't ask.).....Thanks in advance for yall's input.IMAG0257.jpg
Aka:~KILLER~
  #24 (permalink)
Old 20 Jun 2013, 09:56 pm
Well, they do not work exactly because of the picture you posted.. You need that RKE module for power door locks to work..
  #25 (permalink)
Old 21 Jun 2013, 08:24 am
Thumbs up Re: Door lock problems
Well,then I guess my mystery is solved,THANKS........I'm still curious;Is there any possible reason why it would have been removed,and NOT put back??(I'll entertain speculation,LOL)....It was a PITA to get to IMO.....Also,if I get a RKE Module from a salvage yard does it need to be 'programmed'??....And can I get 'key fobs' that will mate up with it???...........
Aka:~KILLER~
  #26 (permalink)
Old 22 Jun 2013, 10:05 am
Well,good news is....I found a used RKE module for $39.99(Part#P046​71879AB),a Key Fob/Remote Transmitter for $14.88(Part#04671641)hope those are all the right part #'s for a 2003 PT Base????......And I think I have found instructions for programming the remote to mate up with the RKE module???How to Program a PT Cruiser Keyless Remote | eHow If this is correct it will save me the $70 my local Chrysler dealer wants for programming!(and it sounds PRETTY simple)........I would appreciate some opinions,Thanks.....Randy
Aka:~KILLER~
  #27 (permalink)
Old 22 Jun 2013, 01:35 pm
Question Re: Door lock problems
I am slightly curious.....I know this key/fob says it's for 2006-2008 PT Cruiser,but I was wondering if anyone knows if it would work with a 2003 PT Cruiser with power door lock & RKE module????06 08 Chrysler PT Cruiser Aspen Remote Key OHT692427AA | eBay
Aka:~KILLER~
  #28 (permalink)
Old 24 Jun 2013, 03:58 pm
Talking Re: Door lock problems
Holy Pony Express Batman!!!!!........My RKE Module was in my mailbox today!!!!(I can't even send a letter across town that fast!)....I'm gonna go ahead a recommend (just based on fast shipping) D.A.N. Auto Parts in Spokane,Washington.......Module is in great condition,and on the reverse side it says "03 PT CRUISER" in siver paint pen(Ebay listing said: 03 04 05 PT CRUISER NEON BCM DOOR ECU KEYLESS RELAY )....And maybe this evening when the Heat Index gets below 104 I might go put it in!(I'm in no hurry)....Also got my 'remote/key fob';...It does have instructions that contradict what I found on Ehow.com...It says I need to have at least 1 existing remote,but I'll give her a go & let y'all know! ~Addendum~....Online most information states: a dealer DRB scan tool is used to program the key fob remotes (transmitters) to the RKE. You might check a dealer service department as to the cost of such an installation....IDK
Aka:~KILLER~
  #29 (permalink)
Old 09 Jul 2013, 10:18 am
Question: If I install the RKE,does it have to be programmed to work just the power door locks?....I know it needs to be programmed to recognize the remotes/fobs for them to work...Unless you have one that already matches the RKE.....But,until I go somewhere(dealer/shop/locksmith)to get that done would installing the RKE cause any problems with starting/driving,or anything else?
Aka:~KILLER~
  #30 (permalink)
Old 09 Nov 2017, 07:21 pm
Just wondering if the RKE module is the same for all the models of 2001-2005. I have a 2005 convertible, but the RKE from a 2001 sedan doesnt seem to work? Also have access to one from a 2005 sedan, if you think that will work.
Ignition and Steering Lock Problems PTNoob01695 General PT Cruiser Discussions 10 12 Aug 2012 02:57 am
DOOR LOCK PROBLEM smiley87 General PT Cruiser Discussions 3 05 Oct 2008 08:38 am
Anyone else have lock problems on an 06? dag General PT Cruiser Discussions 5 16 Mar 2006 08:55 pm
door lock question jleforte Tech & Performance Forum 15 10 Jan 2005 08:56 am
NEW DOOR LOCK PINS 1MEAN PT Interior Accessories Forum 1 04 Jul 2003 02:02 am
