transmission fluid
Old 06 Feb 2011, 10:57 pm
Send a message via Yahoo to partyd
Default transmission fluid
I change my transmission fluid in my 2004 auto ( autostick )when i reach 35k miles
it was simple to do and change the filter and gasket no problems
yesterday we open the oil pan of my friends 2003 auto ( autostick )
and let the fluid drain till this morning and it rain last night, we found no water near the tranny but it was a humid day ,today we clean the oil pan and the tranny install a new filter and gasket the problem is that now
the vehicle don't shift no computer error codes after trying for a few minutes
it shift on second gear but i sill have a problem
using mopar aft4
2008 Pt cruiser Touring
2004 Pt Cruiser GT
2004 Chrysler 300M
2008 Chrysler Pacifica awd
Old 07 Feb 2011, 12:20 pm
Dino's Avatar
Default Re: transmission fluid
Was he having any problems prior to this? Is it the correct filter? Did you check the fluid level again after noticing the problem?
Old 07 Feb 2011, 03:54 pm
there was never a problem before, i told him that it will be a good idea to replace the fluid and filter, auto parts tell us 4 botles is enought
but online shows 6 to 7 we didn't remove that much fluid
2004 Pt Cruiser GT
2004 Chrysler 300M
Old 07 Feb 2011, 04:08 pm
cruserdad1976's Avatar
Mine took 6 full quarts of ATF 4 are you 100% sure you got the filter back in all the way???? it wont suck if it is not seated
other thing is some on here say that after a drain and fill the tranny has to have a relearn done to it at a dealer mind did not but some say theres did
Old 07 Feb 2011, 09:47 pm
VNT's Avatar
VNT VNT is offline
Did you use a mopar filter, did you get the filter correctly seated?
Did you check the fluid level after the trans warmed up to make sure it is full??
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 07 Feb 2011, 09:55 pm
I got to say that 4 quarts in not enough
Old 08 Feb 2011, 11:45 am
Dino's Avatar
I agree, especially if he let it drain all night, check the dipstick after it's warm
Old 09 Feb 2011, 10:33 pm
The trans takes like 8 quarts when totally drained including torque converter. But since you can't drain the converter, generally 4-6 quarts it what it takes to fill on a filter change.
When you install a new filter, you need to make sure the old o-ring came out and you put on the new oring on the new filter.
Now this poses another issue... even if the fluid it very low, you wouldn't have any engagment also very low fluid level will set a code for loss of prime. However you'd need to use a real scanner to read trans codes not engine computer version of trans codes.
Changing Transmission Fluid garyerrol Tech & Performance Forum 13 27 Jun 2016 05:02 pm
transmission fluid leak joeus Tech & Performance Forum 11 11 Jul 2013 09:18 am
Transmission fluid leak tryanmax Tech & Performance Forum 19 22 Jul 2012 02:16 pm
Transmission Fluid scatgo Tech & Performance Forum 4 31 May 2009 09:04 pm
Transmission Fluid DaShado Tech & Performance Forum 1 02 Jul 2007 06:18 pm
