Can you replace the actual tie rod? Not the ends, the actual rod itself.
Old 07 Feb 2011, 01:31 pm
Default Can you replace the actual tie rod? Not the ends, the actual rod itself.
Got an 09 PT Cruiser that was struck on the driver tire that bent the tie rod.
Basically the rod that you attach the outer tie rod end onto, it has the treads on it for alignment adjustments etc.
Can you change that rod on it's own?
Old 07 Feb 2011, 01:39 pm
Default Re: Can you replace the actual tie rod? Not the ends, the actual rod itself.
Welcome to the forums.
Why wouldn't you be able to? Of course, you'd need an alignment after...
Old 07 Feb 2011, 02:20 pm
Its not attached the steering rack in way that you can't change it without removing the rack? I guess when you think about it, you can change inner and outer tie rods ends so that you have to mean the rod in the middle at some point can be totally removed.
Is this a part shared with neons?
Old 07 Feb 2011, 03:03 pm
UptownSport's Avatar
Look it up inner tie rod @ Rockauto.com
There are special inner tie rod sockets that reach in far enough to R&R w/o rack removal
Last some one asked (search) they hadn't listed an inner tie rod for late models, not that they aren't made, just that there's not enough demand yet to bother listing- if that makes sense.
The dealer has never listed that part separately, unless things have changed.
Old 07 Feb 2011, 03:19 pm
Actually I just came back here to post that I believe that rod and where it attaches to the rack is probably what is called the inner tie rod.
I got a couple more places to call.
Old 07 Feb 2011, 04:23 pm
Had to go through the dealer, but it was only 68 bucks woot.
Inner tie rod ends on an '07 replaceable? 2007 General PT Cruiser Discussions 7 15 Jan 2011 10:43 am
A few odds and ends: Candyman Classifieds: For Sale/Trade 6 06 Sep 2009 08:32 am
tie rod ends help musicmanchuck4 Wheels, Tires, Suspension 0 14 Apr 2009 12:52 pm
Actual HP? beachknight PT Cruiser Convertible Forum 3 16 Apr 2007 01:56 pm
tie rod ends Swngdncr General PT Cruiser Discussions 6 05 Mar 2004 12:33 am
