compass and outside temp
Old 08 Feb 2011, 10:41 am
Default compass and outside temp
I've read thru just about every posting on this topic and still haven't found a definite answer. My problem is 2 parts
1st, outside temp reads -10F all the time. I disconnected the sensor and it reads -49f and if I jumper the wires it reads 140f. I tried a known good sensor and same results -10f. I measured resistance of sensor and it is right on for temp. I then heated the sensors with a hair drier and no change on the display.
2nd. Compass only shows direction of where ever the vehicle was when it was started. IE, my garage faces NE. That's what the compass says all the way to work driving south. then I start my car up at work which is facing west in the parking lot, the compass reads W all the way home as I drive north. I've done the calibration proceedure numerous times. I do not have any aftermarket stuff in the car that would crate magnetic interference.
Old 08 Feb 2011, 12:29 pm
meder2487's Avatar
Default Re: compass and outside temp
That may be a bad control module. I have never replaced one of these in a PT but I have in a Town and Country minivan. The fuel mileage and temp readings were off in the van and it turned out the controller, which was located behind the drivers side kick panel had gone bad. I do not know the location of the module on the PT. But it may be worth trying to find it and see if it is functioning.
Don't Blink
Old 09 Feb 2011, 07:30 pm
All of a sudden the compass started working correctly , but the temp is still stuck on -10F. Again, I unplug the sensor and get -49F on the display and when I jumper the 2 leads for the sensor with a paperclip, I get 140F. But with any sensor plugged in, it always reads -10F. I even heated the sensor with a hair drier and no change to the display output.
Old 09 Feb 2011, 07:52 pm
BladeRunner's Avatar
You don't say what yr you have,but, it probably will be the same. It sounds kinda like the sensor is toast. But, because the compass started working again..maybe because you have been moving the wires around. It could be as simple as bad connections. I have an '01 I got last Oct. I needed to replace 3 bulbs in my dash cluster. I did all six and 3 still wouldn't light. I took the PDC ( power distribution center) under the hood apart. Under the bottom I found several "green" connections..corrosion After I cleaned and greased every connector all the dash lights were good. So, that might be a place to consider checking.
BTW, I have an '01 Caravan...very similar to the PT as far as electrics go, my outside temp display went nuts one day....very high temps..and it wasn't that hot outside.
Turns out the sensor has a plastic part that screws onto the center support in front of the rad...well that mount broke away somehow and the sensor was sitting against the rad. I ty wrapped it back in place and it's been fine ever since.
Old 09 Feb 2011, 10:27 pm
yes, it's an 01. I said that I tried different sensors (using a known good sensor). Infact I put the PT sensor into minivan and it worked perfectly and I put the minivan sensor into the PT and same results -10F
Old 10 Feb 2011, 04:37 pm
Just for grins...take a look @ those connections under the PDC..you may be surprised what you find.
Old 11 Feb 2011, 09:39 am
I did that and everything looks like brand new. Just seems wierd that everything checks out fine, (sensor Ohm's correct and tried a known good one, unplug sensor and -49F is correct for open circuit, 140F with jumper wire also correct). Weird that with any sensor plugged in it reads -10F. Inside my garge it's 60F and outside it was 12. with the car inside or out, no change in temp at all. When I heat up the sensor with a hair drier, no change on the display, yet the sensor(s) changed resistance which should have shown a change on the display... Yet still stuck at -10F
Old 11 Feb 2011, 03:44 pm
I would change the connector. It must not be making good contact with the sensor. Why it reads -10 and not -49 is the strange part.
Old 11 Feb 2011, 04:35 pm
I back probed the wires with a potentiometer in the resistance range the temp sensors work off. Before I connected the Potentiometer, I have -49F (open circuit) I connect the Pot. and it reads -10F, I turned the pot. and thru the entire reistance range, the temp is stuck at -10F. The only way my outside temp display changes is when I open the circuit (-49F) or short the circuit (140F). To summarize, no sensor -49, with ANY sensor or resistance -10 with a shorted circuit 140. NO other number ever shows up other than those 3 I've listed.
Old 20 Feb 2011, 09:44 pm
This thing is driving me nuts. Now the temp works fine but the compass is stuck. I drove 30 miles due north and the compass never changed from WEST. WTF
ambient temp &compass C300392 Interior Accessories Forum 6 06 Dec 2010 04:11 pm
Is it possible to activate compass? 66CUDA Tech & Performance Forum 3 15 Jun 2009 08:00 am
compass/outside temp reading bandbpt General PT Cruiser Discussions 6 05 Jun 2008 03:36 pm
Compass and Temp aftermarket? neps Interior Accessories Forum 28 30 May 2004 10:14 pm
Overhead Compass/Temp too Dim - Try This Dalite Tech & Performance Forum 11 01 Jul 2003 10:42 pm
