Muffler weep hole
Old 09 Feb 2011, 05:02 pm
Default Muffler weep hole
I did a seach and the words are too common to return anything worthwhile at all.
So here goes.
If I was to ask on another forum this question. How about drilling a hole in the muffler? They would think I was crazy. It will be loud, and leak exhaust into the car and kill me.
The muffler on the PT have a weep hole under the tail pipe.
What do PT owners say to this?
BTW, have any owners had their muffler rusted out yet?
Old 09 Feb 2011, 05:06 pm
Kawizx9r's Avatar
Default Re: Muffler weep hole
What's the point of this hole exactly?
I just deleted my muffler and had a straight pipe put in it's place along with exhaust tip. Then again I've got a turbo and the muffler-delete frees up some of that pressure.
Kawi is a friggin genius!
Old 09 Feb 2011, 05:13 pm
BladeRunner's Avatar
I understand the purpose of having a weep hole. I don't know for sure if mine has one..never looked. But, I do know, if you make a lot of short trips..like to the corner..run errands etc. The exhaust won't have enough time to "dry out" the muffler. Hot moist gases (condensation) form in there and will rust out the muffler fairly quickly. I think a minimum of 20~30 min of driving is needed to dry out the muffler.
Old 09 Feb 2011, 05:30 pm
cruserdad1976's Avatar
I have a 06 na auto and it has a small maybe 3/8 maybe 1/4 hole in the muffler under the exhust tip IM betting that is a weep hole
there is no way it would make the car loude or kill you it is simpy to keep the muffler dry
Old 09 Feb 2011, 06:44 pm
Having a weep hole at the tip, I don't see how that would affect the muffler, if the hole is in the bottom rear of the muffler then moisture could escape..by gravity. It doesn't have to be large..1/8" is probably fine; Also, many people forget about the weep holes in door bottoms, they need to be cleared periodically..other wise the "stuff" that builds up in there will rot the door bottoms
Old 09 Feb 2011, 06:45 pm
under the tip
Old 09 Feb 2011, 07:10 pm
The Pot Hole Won! coondog Classifieds: Want To Buy 4 02 Jul 2010 01:39 am
Hole In Radiator h100250 Tech & Performance Forum 6 10 Nov 2009 05:17 pm
Stock Muffler V.S. Aftermarket Muffler... DEEFIEND Tech & Performance Forum 4 08 May 2008 06:21 pm
Hole in Muffler JustCruisin General PT Cruiser Discussions 2 01 Nov 2007 06:05 pm
Firewall Hole Stephen R. Tech & Performance Forum 1 09 Mar 2002 05:56 pm
