rough idle after timing belt change?
Old 23 Feb 2011, 07:55 am
Default rough idle after timing belt change?
2001 pt cruiser 90,000 miles did belt, water pump, tensioner set timing per instructions and came up with same result! confused! starts up and runs drove several days, but idle still remains same. replaced iac and egr also map. seems the forum suggests all the issues. any help for resolve is appreciated.
Old 23 Feb 2011, 08:34 am
Default Re: rough idle after timing belt change?
So, you had rough idle before the timing belt change??
Rough idle usually caused by (in order of liklihood)
1) Plugs and wires - wires every bit as important as plugs - gap plugs at 0.040
2) Intake gasket - spray starting fluid along intake manifold seams - if idle gets smooth, then it's intake gasket
3) stuck/clogged injector
4) timing belt off a tooth
5) burned valves/no compression
Old 23 Feb 2011, 10:21 am
did not appear to have rough idle before repairs, changed out plugs and wires per forum discussions. car had water pump leak and appeared to be running fine, cleaned throttle body as well, injectors could be possible. have set and reset the timing numerous times. still no resolve. any other ideas.
Old 23 Feb 2011, 11:30 am
themadgreek187's Avatar
i am having this issue as well. changed out plugs and wires and gaskets. still a small stumble.
Old 23 Feb 2011, 12:52 pm
Then the timing belt is probably off by a tooth... I've read that it is very tricky to get set right.
Old 23 Feb 2011, 02:18 pm
had mine checked. all is good with it.
Old 23 Feb 2011, 08:59 pm
UptownSport's Avatar
Had the living heck confused out of me. Unlike the 2.0 side, the 2.4 side has two hatch marks per gear! Basics are to get the 1/4" holes straight up to begin with, glad I did, other wise I'd a had it wrong.
Can't tell you how many times I changed it back- forth a tooth 'til I noted the extra marks!!!!!!
Old 24 Feb 2011, 08:36 pm
not sure what holes you are talking about? got the arrows up and the on 2.4 cam gears and marks showing still no cigar? can you explain the holes?
Old 24 Feb 2011, 09:37 pm
Is the piston in #1 cylinder at TDC??
Old 25 Feb 2011, 03:08 pm
checked and rechecked yes it is. any other solutions? confused!
rough idle after changing timing belt CJDoble Tech & Performance Forum 7 30 Jul 2015 08:59 am
after oil change, rough idle first, smooth out later edb General PT Cruiser Discussions 8 14 Feb 2011 04:40 pm
Timing belt change - is this possible? nx13688 Tech & Performance Forum 1 14 Oct 2010 06:50 pm
rough idle after changing timing belt on 01 pt EnragedDolph Tech & Performance Forum 2 13 Oct 2010 03:51 pm
after timing belt idles rough dpmeeks Tech & Performance Forum 7 21 May 2009 06:00 pm
