My PT eats wheel bearings
Old 28 Mar 2011, 10:15 pm
Default My PT eats wheel bearings
it seems like every year I need to replace a wheel bearing on my '05.
Am I doing something wrong or are these a fragile part of the car?
Old 28 Mar 2011, 11:31 pm
WolfmanG's Avatar
Default Re: My PT eats wheel bearings
what about your ground wires, are they good? i'm talking about the ground wire that's connected to the shock or something. if i can find a pic of it i'll show you what i mean.
-Danny Wolfman G
Old 28 Mar 2011, 11:36 pm
WolfmanG's Avatar
this one, i think it might have something to do with it. idk but someone might. good luck
-Danny Wolfman G
Old 29 Mar 2011, 12:51 am
Stock or Aftermarket wheels? If Aftermarket, what is the width and the offset ... post picture.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 29 Mar 2011, 05:31 am
Stock steelies with Pirelli P4s
Old 29 Mar 2011, 05:38 am
[QUOTE=WolfmanG;352271]this one, i think it might have something to do with it. idk but someone might. good luck
[IMG]
Honestly I have no idea, but I need to replace some bushings so I'll check it out while i'm in there
Old 29 Mar 2011, 05:53 am
What are the symptoms you're getting that tells you you need bearings?
Old 29 Mar 2011, 06:25 am
What WolfmanG is referring to is this "sticky" which on the top of the suspension part of the forum...
Front Ground Straps to struts, WHY?
Old 29 Mar 2011, 06:29 am
WolfmanG's Avatar
Thanx for the back up CREWZIN.
P4's huh. lol i got three of them and one of them is a p5.
-Danny Wolfman G
Old 29 Mar 2011, 10:47 am
Good Answer ... I wonder about those with 24's sticking 8 inches out of the wheelwells.
How many miles and which bearings are failing front or rear, have any failed more than once?
Also if front, which side.
12 Regal Turbo
90 F150
73 Mach1
Bye Bye wheel bearings turbomangt General Turbo Discussions 71 18 Jun 2017 08:32 pm
Best front hub/wheel bearings to buy? Samson Wheels, Tires, Suspension 9 13 Aug 2010 11:45 am
How can you tell if you need new wheel bearings??? Ironman Tech & Performance Forum 5 09 Dec 2009 09:29 pm
Wheel Bearings dadart Wheels, Tires, Suspension 5 28 Jan 2009 01:00 pm
Bad wheel bearings VandyCruiser Wheels, Tires, Suspension 6 06 Sep 2007 09:08 am
