Fuel Gage And Sending Unit Problems
Old 02 Apr 2011, 09:39 am
Unhappy Fuel Gage And Sending Unit Problems
Hoping for some direction on the my fuel gage problems - Gage has been "stuck" at low fuel reading with the low fuel light on, even with a full tank of gas. looked in forums and it appears to lead to a fuel sending unit problem - I did the self-check on the instrument panel and all gages worked fine. I took to Chrysler dealer and discussed with service advisor - indicated that fuel sender most likely faulty and needed replacing - One ordered and replaced in the tank at $120 and 2 hr labour = $300.00. This did not fix the fuel gage reading - it did briefly get to 1/4 tank reading at a full tank, but is back to original problem sitting at low fuel reading - The dealer is going to look at problem again - I am concerned that they will be looking to replace the gage cluster?? Is there any suggestions and idea on what to look at: ie loose ground wires, etc that I could do first
Thanks and appreciate everyone's insight
2005 PT Conv Inferno Red - turbo lite- 30000 KM
UPDATE: Went back to dealer - indicates that the gage cluster is OK - now suspects that there is a wiring problem from sending unit but will need to remove tank again to investigate - would have thought that they would check out wiring etc prior to replacing sending unit?? Need to run out tank of gas first and I will report back ------ any ideas??
Oil Pressure Sending Unit DEEGO Tech & Performance Forum 20 22 Feb 2016 06:24 pm
fuel level sending unit dbcruiser General PT Cruiser Discussions 2 13 Aug 2010 12:17 pm
How do you know if it's a bad pump or sending unit? scrisp2 Tech & Performance Forum 4 18 Nov 2008 08:44 pm
Oil pressure sending unit littleblueGT Turbo Performance 3 27 Oct 2004 02:44 pm
Oil Sending Unit rockycruiser General Turbo Discussions 9 15 Oct 2003 11:30 am
