tranny swap?
Old 06 Apr 2011, 10:43 am
Default tranny swap?
Have a 2007 PT touring with the 2.4 and 4sp auto.
In our local scrapyard sits a new 2011 Chrysler 200 that was rear ended.
It also has a 173hp 2.4 mated to a new 6 speed Automatic with autostick... Anyone know if this 6 speed will mate up to the 2.4 in my PT? Love the thought of the pt having a 6 speed tranny... Would engine and tranny fit?
I can get the Engine and tranny for 450 bucks- or 250 each..
Old 06 Apr 2011, 01:43 pm
Default Re: tranny swap?
Get the whole car ....
You will need wiring harnesses and computers for the engine and tranny. As for fitting under the hood ... I have only seen the 200 in the SuperBowl Commercial and the one they started airing last week that makes it look a lot better than it did in the SuperBowl Commercial.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 06 Apr 2011, 04:23 pm
I doubt you can get it to fit, but what the heck, at that price it's almost a give-away. Cost you triple that for a used 2.4 with a Getrag 5-speed.... course with our 2.4 you get more HP.
Old 06 Apr 2011, 06:16 pm
Wondering if I could just swap the tranny... Is there a big difference in the 2.4s used in PTs vs the 2.4s used in Calibers, Patriots and the Avengers and 200's? I just always assumed the PT's 2.4 was never upgraded because they were abandoning the platform... the newer 2.4s have much more HP and Torque with better fuel economy... is it a totally new engine or simply an updated one? Do not really want the whole car as it has been hit rather hard in the rear... rear end is crushed up into the rear doors. Front end is spotless and the car only has 1,300 miles on it. Oddly our PT only has 23,000 on it so an engine and tranny swap may seem foolish... but the idea of a 6sp auto is exciting with a marked gas mileage improvement
Old 06 Apr 2011, 09:49 pm
You got one out of three right... should look at the specs on the HO 2.4 on the PT GT. 173hp??? That's downright wimpy compared to what I'm putting out... or rather what my PT is putting out....lol....
Old 07 Apr 2011, 08:23 am
at 150 hp the PTs 2.4 was underpowered.
by comparison a 2.4 Dodge caliber put out 172 HP. 165 lbs Torque
Are these basically the same engine with a different top end?
if they share the same block I would imagine the tranny's would swap with little fabrication...
I just never understood why the PT didnt get the 172 hp 2.4 in in 2006 with the VVT Was the PT the way to use up leftover stock? If a car needed more standard HP and torque it would have been the PT
Old 07 Apr 2011, 08:42 am
UptownSport's Avatar
That 2.4 is 'world engine' or some other silly moniker.
It has an Aluminum block, a nifty thermostat for both block and head,
has a dual stage intake (Like the Neon H.O. 2L)-
I don't believe it shares ANYTHING in common with the Neon based 2.0/2.4
It's mated to the t-355, which is very similar to our NVT-350, but only
similar (believe me, as soon as caliber came out, I looked up EVERY part
number!!)
HP output doesn't tell the whole story; cast iron blocks are well suited for HD
applications, like moving a C-van or a PT- Or the Dakota. It has a very long
stroke, which may not be suited for high power output, but builds tons of
torque down low, again, where a van or PT needs it.
I'd suggest swapping to a T-350 5 speed, simple, cheap, proven.
No computers!
Old 07 Apr 2011, 09:33 am
Thanks!
I believe I will pick up this engine and tranny... at 450.00 its a steal... especially considering it only has a few miles on it.. I am going to grab it all--- air intake and all the wiring as well.... Then do I flip it for profit or use it in some future project car? it would be a hoot in something weighing around 2000 lbs... lol
Old 07 Apr 2011, 09:46 am
HAHAHA .... I always wanted to fit a modern VW GTI or maybe Audi A4 1.8T or 2.0T into a Porsche 914 .... bet it would get better MPG than the original VW inspired Fuel Injected Pancake engine .... if I could get it to stay on the ground.
12 Regal Turbo
90 F150
73 Mach1
Old 21 Nov 2013, 12:10 am
SillyRobot's Avatar
I was wondering this. The new Dart has a 2.4 with a 6-gear. But I looked at it again, the 6 is close-ratio. I want a third overdrive gear that would let me run 70mph at closer to 2K than 3K rpm. For a while I had a 70 mile commute and could regularly get 30-31 mpg. Now with 200K plus miles and a 4 mile commute I get about 23. As was said, the 2.4 PT engine has plenty of torque. I am thinking about doing an engine rebuild that would optimize performance, not maximize it.
2002 Ltd Ed, Original Owner, Currently 20X,XXX miles, Optima Red75/35, Airaid Air filter, Energy Suspension urethane bushings, Shift Boogers, Monroe Struts, MSD, LED front turn signals and all rear lights.
I have gotten 30 mpg when I had a long commute in 2006-7, but the mileage has dropped to the mid 20's and it's consuming a quart of oil a month.
Turbo Swap out??? HAPPYDADDY76 Tech & Performance Forum 2 30 Jul 2008 06:06 pm
2.4l Pt swap fork_in_the_road Classifieds: For Sale/Trade 0 03 Oct 2007 09:21 am
tranny swap buttersandpaper General Turbo Discussions 6 15 Sep 2006 03:49 pm
tranny swap VellianPT Tech & Performance Forum 4 02 May 2005 08:45 am
SRT-4......GT Swap... COP TZER Turbo Performance 6 24 Jul 2003 12:34 am
