How to remove luggage compartment trim
Old 09 Apr 2011, 02:12 pm
Default How to remove luggage compartment trim
Hi
I am trying to remove the passenger side (UK) or drivers side (US) luggage compartment trim to get to the wiring loom from the tail light. I removed the four screws that are obvious but it just wont budge. I tried the Haynes manual and it does not mention this trim panel.
Any ideas anyone?
Thanks
Old 09 Apr 2011, 02:31 pm
Default Re: How to remove luggage compartment trim
From a shop manual (2004)
"LOWER QUARTER TRIM PANEL REMOVAL
(1) Remove upper quarter trim panel.
(2) Disengage clips attaching trim to lower quarter
trim panel.
(3) Remove cargo tie down trim panel.
(4) Remove lower quarter trim from vehicle."
(In addition to the screws, there are snap in place fasteners that can be tight).
"UPPER D-PILLAR TRIM REMOVAL
(1) Disengage clips attaching trim to D-pillar.
(2) Remove upper trim panel from vehicle."
(There are snap in place fasteners that can be tight).
I'll bet the following must also be removed first (and the rear seats tumbled forward out of the way).
"UPPER C-PILLAR TRIM REMOVAL
(1) Disengage clips attaching trim to C-pillar.
DOOR SILL TRIM REMOVAL
(1) Open door to gain access to sill trim.
(2) Disengage clips attaching sill trim to door sill
and door opening flange.
(3) Remove door sill trim from vehicle."
Any ideas anyone? Thanks
Old 09 Apr 2011, 02:45 pm
I'm pretty sure you have to take off the panel on the D pillar that covers the rear speaker (if you have one) and the scuff plate (the one by the bottom of the hatch opening with ridges on it) and my parts book shows a 5th screw down by the bottom edge about midway between front and back edge. You might also have to take off the scuff plate at the bottom of the opening for the rear door and the panel over the inside of the C pillar.
Opps, Santa beat me to it.
Old 09 Apr 2011, 02:47 pm
Brilliant, thanks for your speedy reply. I shall give this a go tomorrow.
best way to remove the radio/center trim? pppt03turbo Exterior & Interior Styling 10 23 Nov 2008 07:10 pm
Engine Compartment Pics gonzomania General PT Cruiser Discussions 2 28 Mar 2005 07:52 pm
engine compartment gonzomania The Detail Shop 1 30 Jun 2004 11:56 pm
Glove Compartment Light rnbenoit General PT Cruiser Discussions 1 09 Apr 2004 09:55 pm
