Compression problem
Old 09 Apr 2011, 03:06 pm
Angry Compression problem
Just failed state emissions testing for misfiring in #4 cyl
Plugs and wires are new and coil is ok
Compression test on #4 shows 60psi, all others ok
Car has 50000 miles, and is a 2004 GT turbo
Was quoted over $2000 to fix the problem, which was diagnosed as sticking valve
Walls of #4 cyl are clean
Misfiring has almost gone away with new plugs and wires
Any suggestions
Old 09 Apr 2011, 03:28 pm
Default Re: Compression problem
If you don't want to pay the money to pull it all apart, there is some "stuff" on the market (forget the name) that's supposed to help with sticking vales. Check your local auto store. Might not work, but can't hurt.
Also, if you do a Google search for "help with sticky valves" there's lots to read and maybe some help for you.
Old 09 Apr 2011, 04:09 pm
Thanks
I'll check it out
Old 09 Apr 2011, 04:34 pm
Fill up with the highest octane gas you can find. 93 is good, if you have 100 or 101 race fuel around you (me I have it at almost every gas station), then mix about 5 gallons of that in with 93. Get you a can of Seafoam, and dump that into your gas tank, save 1/4 of it for your oil. Dump that last 1/4th into your oil. Now go drive for an hour, find some hills to pull up, get on some steep inclines, you need to stress that engine big time! Me, I hit the highway and take it to about 105, then slow down to 85, then go up I-40 towards Asheville and jump on the Blue Ridge Parkway, then run like I stole it.
Not only cleans out everything, but the amount of effort in pulling up those hills, and that fast run, with the Seafoam in it, tend to snap free a stuck valve. Now be careful, it's usually carbon coated from crappy gas, f/a mixture, spark/timing advance, or any number of things. If that spring snaps, you're in trouble and will end up with the top of that valve slinging around on top of your piston head, and then you're talking a rebuild.
Me, I've had stuck valves now on three vehicles, the last being my wife's 2008 Town and Country just two months ago - she's got the 250hp 4 ltr V6 in it, started running funny and smoked a lot, especially when cold. I took it out on the highway after adding in Seafoam, ran it up to about 80 when I hear this kind of snap sound, all of a sudden the engine seemed to come alive! I pulled off at the next exit, opened the hood to make sure nothing was visibly wrong, found nothing. No smoke out of the rear end. Went to turn the corner and spun the tires! Gave me a heck of a laugh!
Old 17 Apr 2011, 11:08 am
Decided to remove the head and replace the sticking valve
It will cost $1500, but the car is a loaded GT and has only 50000 miles
I'll probably keep the car forever
Thanks for the suggestions
The no compression engine PTProblems Tech & Performance Forum 2 01 Apr 2011 09:15 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
Compression fittings on terminals 2step Sound and Security Forum 4 15 Jan 2005 05:02 pm
compression fittings Punch Exterior & Interior Styling 10 11 Nov 2003 10:36 pm
compression fittings? Punch General PT Cruiser Discussions 4 02 Oct 2003 12:59 pm
