PT Overheating
  • 1 Post By Mabel
Old 09 Apr 2011, 05:09 pm
Default PT Overheating
I've seen that the radiator fan is the weak link.
I was a stoplight yeterday and the hot water light came on.
I've got a 2004 PT, non - turbo.
Added coolant and oil - also new fuse - Seems to be going OK now.
How much of a hassle is it to get to and replace the radiator motor, if that is necessary?
Old 09 Apr 2011, 07:54 pm
Default Re: PT Overheating
If you can find just the motor, you still have to take out the entire fan and housing to install the motor. Most people replace the fan and housing from eBay.
Removing the fan and housing 01-05 PT
Old 13 Aug 2011, 12:01 am
Today we replaced the fan motor and housing in my'01 Cruiser. Before we installed the new motor, we tested and it worked fine. After install we ran the car for about 20 minutes in the driveway. Temp gauge stopped at 1/2. We then drove it about a mile. When we got back the fan was not working again and the radiator fluid was boiling. We tested the fan again and it won't come on. Any suggestions?
Old 13 Aug 2011, 06:40 am
Mabel,
You've already tested the fan so you know all about it. The connection that's about 10 inches from the fan motor can be used to see if the fan is still good. Run a hot and ground wire to that 3 pin connection. Ground the middle pin and touch the hot wire to either one of the outside pins to see if the fan is working.
If the fan comes on with the testing, it sounds like you have a short somewhere in the wiring. It might even be in that connection you used to test the motor. Make sure it's making good contact with the wires from the harness.
Old 15 Apr 2012, 03:40 pm
I should have posted this update before. We simply had to replace a fuse and the fan motor began to work properly. I appreciate everyone's willingness to help and answer questions.
Busted_PT likes this.
Old 20 Apr 2012, 11:15 am
hey ive had a overheating problem can anyone help ive changed the thermostat the fan realy fuse fixed the leask checked the radiator and even got a new radiator fan and also changed the sensor to the radiator fil tank now it still overheats i feel like ive lost hope any suggestions?
Old 20 Apr 2012, 06:41 pm
Overheating = radiator fan not working properly (both speeds), partially clogged radiator, bad thermostat, water pump not working, trapped air in the coolant system, cracked head gasket, cracked head.
Old 10 May 2012, 10:57 pm
Guys, I've seen postings time and again about the radiator fans and guesses as to diagnosing the problems, overheating engines, etc. In the OEM Service Manual there is an entire section dedicated to the engine cooling system and how to troubleshoot it. I was going to post this in my library thread but it's locked, so I'll post it individually until Crewzin unlocks it.
Now, the service manuals are different for '06 and up, however if I were you and I was troubleshooting overheating problems, I'd download both because they both have excellent info in them.
Here they are, you can download directly from my web library:
2000-2005 PT Engine Cooling System
& 2006 and up PT Engine Cooling System.
Overheating...Please HELP Bliss General PT Cruiser Discussions 2 10 Jun 2012 12:46 pm
overheating earle Tech & Performance Forum 67 04 Oct 2010 06:49 pm
Overheating kporcenaluk Tech & Performance Forum 5 01 Sep 2010 08:48 pm
OVERHEATING zanno Tech & Performance Forum 2 05 May 2010 06:27 pm
03 Overheating Cruisjim General PT Cruiser Discussions 16 24 Dec 2009 09:26 pm
