checking a starter solenoid
Old 10 Apr 2011, 03:50 pm
Default checking a starter solenoid
I have a 2002 pt cruiser and I have been having trouble starting it up. I turn the ignition to which the motor turns once and then begins clicking. I tested the battery and got a read out of 11.9 V. At one point, while I was driving the left turn signal went cuckoo. Furthermore a panel light behind the speedometer no longer works. I am hoping that this is a seperate issue. I checked the fuses and they all seem to be in tact. I read on another forum that this type of issue can be resolved by replacing the solenoid with that from a 95 jeep cherokee.
PT starter problems
I was wondering if there is a way to test the solenoid and also where to locate it. I tried finding images on it, but was unable to do so. If there are any other prelim diagnostics I can run that can help me determine the issue it would be greatly appreciated.
Old 10 Apr 2011, 06:45 pm
Default Re: checking a starter solenoid
Look down between the radiator top and the upper manifold. The a cylinder looking thing with a big red wire going to it. That's your starter solenoid which is on top of the starter itself.
I don't know how to test it.
Old 11 Apr 2011, 03:54 pm
Hey thanks for the reply,
I thought it might be that, just wanted to be sure.
01 PT Cruiser Starter Solenoid Connections Cruisermania Tech & Performance Forum 3 19 Jan 2011 04:41 pm
Just checking in McNary61 General PT Cruiser Discussions 16 14 Jan 2011 01:46 pm
New guy checking in..... Wishbone General PT Cruiser Discussions 11 12 Sep 2010 06:27 pm
Starter/Solenoid problem worseforwhere Tech & Performance Forum 5 23 Sep 2008 02:11 pm
Just checking the forums....... PToholics Anonymous General PT Cruiser Discussions 7 08 Jan 2003 03:53 pm
