FAN RELAY FOR 03 GT TURBO?
Old 15 Apr 2011, 08:52 am
Default FAN RELAY FOR 03 GT TURBO?
I looked at the owners manual, and at the power distribution cover searching for the high speed fan relay with no luck! There are 2 empty spaces for the non turbo high speed relay, and the non turbo low speed fan relay in the power distribution box. Does anyone know where they are located, or if the turbo even has them?
I took my GT to the dealer to replace the timing belt, water pump, belt tensioner, upper motor mount, and drive belts. They said the lower mount needed to be replaced as well as the cam seals, and that the tensioner was good. The cost was $1,570.00, and a week later no AC! They checked the line seals, and replaced them at the block. They didn't notice they were damaged when they were removed for the timing belt. Now it appears the high speed isn't kicking in on the fan.
Old 15 Apr 2011, 12:25 pm
Default Re: FAN RELAY FOR 03 GT TURBO?
Take it back to the DEALER!! Tell them of the problem.
Old 17 Apr 2011, 10:27 am
No one seems to have any constructive information! Some one must know if there are relays for high speed and low speed fan on a turbo gt.
Old 26 Mar 2012, 05:17 pm
to bring back a dead thread for those of us that suck a searching...on '03 GT models the fan is run by the pcm/ecu or whatever you want to call it. it is a variable speed fan and it is adjusted fast or slow as needed to maintain the best fuel mileage/engine performance
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
06 PT: Starter relay? Kell Tech & Performance Forum 15 19 Oct 2017 10:40 pm
Cooling fan relay ? facts Tech & Performance Forum 11 22 Aug 2013 10:58 pm
Relay bruent General PT Cruiser Discussions 2 27 Sep 2008 06:52 pm
Radiator fan relay on 03 turbo MINIHEMI46 General Turbo Discussions 2 03 Jul 2007 06:02 pm
A/C Fan Relay? KingKole02 Tech & Performance Forum 7 22 Mar 2006 04:20 pm
