Timing Belt?
Old 15 Apr 2011, 03:21 pm
Default Timing Belt?
Quick question. I think I just broke my timing belt so I removed the cam angle sensor and cranked the motor. It didn't turn.
I assume the timing belt is broke. right?
I'll search the forum for others experiences but I thought I'd ask here.
How tough is it to replace a timing belt on a PT? I've done a few miats in the past but never something like this. the transverse mounting makes it look awful tight in there.
Any advice woulr be awesome.
Thanks guys.
Rich.
Old 15 Apr 2011, 08:27 pm
Default Re: Timing Belt?
I seriously just had this happen to me the other day. I had it first taken to a local mechanic who said he would have to order the part and didn't have the proper tools to fix it. So I had to have it towed to the nearest Chyrsler dealer and they fixed it there. The total cost of it all came out to about 2 grand. they had to fix other pipes and the water pump too though...
Good luck...
Old 16 Apr 2011, 08:47 am
rockauto.com for a kit fitting the PT. It is not a easy job, find a mechanic who had done this before. There are stickys in the performance section that will help you thru the job.
timing belt cruiser4475 Tech & Performance Forum 0 13 Jul 2010 06:24 pm
Belt change help - Not timing belt skfloyd Tech & Performance Forum 2 23 Apr 2010 11:23 am
what timing belt to use? 02ptlimited Tech & Performance Forum 1 12 Jun 2009 07:16 am
