help?
Old 15 Apr 2011, 06:26 pm
infernodreamcruiser02's Avatar
Default help?
my pt kind of shakes when it is just idling.
is that normal?
what could it be?
also when im driving and i have the acceleration at a constant level i can hear this kind of high pitched humming.
anything to worry about?
help please
2002 Limited Edition Cruiser W/ Flames
Old 16 Apr 2011, 08:41 am
Default Re: help?
How many miles? NA or Turbo? Main reason I found out at idle is plugs and wires, any wires except stock. I had a idle miss with less than 500 miles, changed both and shake went away. The humming, I know nothing about!!
Old 16 Apr 2011, 09:04 am
chigger_ns's Avatar
Default Re: help?
Im thinking you should check your motor torque arms [motor mounts on the passenger side], upper and lower. Rubber inserts are probably shot.
This is really common. I would buy after market if possible.
2001 PT 5 speed Touring Edition
Eibach Pro Springs, Energy Suspension HyperFlex Master Kit bushings, 17" RTX Euro wheels, K&N drop in air filter, MotoMaster flat plate AGM battery, KYB GR2 shocks and struts, Booger standard shifter bushings, Ooogah horn.
Old 16 Apr 2011, 01:13 pm
Default Re: help?
You need plugs and wires AND power steering fluid.
Jerry
