Radio display problems
Old 21 Apr 2011, 08:17 pm
Default Radio display problems
My PT Cruiser is a 2001 and the radio display stopped showing but it shows when i turn the key to accessories it use to flicker on and off but just stopped showing all together
Old 21 Apr 2011, 08:20 pm
WolfmanG's Avatar
Default Re: Radio display problems
have you taken it out and checked the wires?
-Danny Wolfman G
Old 21 Apr 2011, 08:25 pm
WolfmanG's Avatar
does the head unit still work? can you still listen to the radio, play cd's or cassets? if so then maybe there's a light out with in the unit.
-Danny Wolfman G
Old 21 Apr 2011, 08:43 pm
If the radio still works when the display is out, try this..................
If you have a key that is newer or in better shape, try it,
I had that happen to me and I used a new key and it hasn't happened since.
If you don't have that symptom, never mind
Old 21 Apr 2011, 08:44 pm
yeah the radio still plays and everything, the display only works when the key is on accessories but not when the car is on, but my dad is going to open it up for me and take a look at it
"Don't let them push you around, for every bruise they give, give them five broken bones"
-Jackal
"I went to the woods because I wished to live deliberately,to front only the essential facts of life,and see if I could not learn what it had to teach,and not,when I came to die, discover that I had not lived.I did not wish to live what was not life,living is so dear, nor did I wish to practice resignation,unless it was quite necessary.I wanted to live deep and suck out all the marrow of life,to live so sturdily and Spartan-like as to put to route all that was not life."
Old 21 Apr 2011, 08:54 pm
WolfmanG's Avatar
oh i see, never mind to what i said earlier about the light being out.
-Danny Wolfman G
Old 21 Apr 2011, 09:54 pm
My kid has had a lot of issues with her radio too .... usually hers are CD related, it was working when she took me for a ride to dinner last night. When I saw you were from Louisiana I thought you might be her ... but then mentioned your dad will take it apart and I made no such promise.
Welcome to the PTCruiserLinks from the 504 AC!
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 21 Apr 2011, 10:33 pm
WolfmanG's Avatar
that's to funny.
-Danny Wolfman G
Old 22 Apr 2011, 09:18 am
We figured it out i had to adjust my steering wheel and it came back on
-Jackal
Old 22 Apr 2011, 09:27 am
Lots of problems with the wiring harness running down the steering column. The wires get stretched or pinched or they pull on the connections when the wheel is adjusted. Most of the time it affects the radio but have seen where it has made problems with other components that use the same wiring harness.
Tags
radio problems
Work owned 2002 PT Cruiser radio display not showing LotusLord Sound and Security Forum 14 11 Jul 2015 11:44 pm
2003 radio problems defflepp1 Sound and Security Forum 2 08 Feb 2009 11:31 pm
Turn off scrolling radio display? antinous Sound and Security Forum 2 12 Jan 2005 12:45 pm
radio problems ds1950 Sound and Security Forum 3 10 Aug 2003 07:00 pm
