Power Windows/Blower/Rear Defrost/Reverse Lights Not Working
Like Tree2Likes
Old 23 Apr 2011, 10:51 pm
Default Power Windows/Blower/Rear Defrost/Reverse Lights Not Working
...and air bag light on. Anyone know what would cause this? I need to get this fixed asap. My summer car has been pulled out of hibernation a little too early because of this. I've searched and haven't come up with much aside from a wire to the fuse box being burnt.
Old 10 Oct 2011, 03:48 pm
Default Re: Power Windows/Blower/Rear Defrost/Reverse Lights Not Working
HI. Did you ever get this problem resolved? I am having the exact same issue. Thanks!
Old 10 Oct 2011, 04:31 pm
Yes. There is a pink/black wire that goes to a harness behind the kick panel on the lower left of the steering wheel, pin 26. The connector in the harness is apparently to weak for the current that goes through it and causes the connector and wire to burn enough to break the connection.
What I did was cut the wire on both sides of the harness and use a "butt" connector to splice them back together and haven't had a problem since. This was back in Apirl so I think its safe to say its good to go at this point
Old 10 Oct 2011, 05:55 pm
Thanks for the quick reply!
I found the gray connector with the pink/black wire just under and behind the fuse box. I tried to pull it out straight down with no luck. Is there a secret to getting it disconnected, or did I just not pull hard enough? Thanks again.
Old 11 Oct 2011, 06:53 pm
If I recall correctly I clipped the wires from both sides of the harness with it left where it was, and it wasn't an easy task...
Old 12 Oct 2011, 04:22 pm
BAZINGA! Successfully repaired!
My main problem was getting enough light in the right place so I could see what I was doing. Then I found the clip on the connector that holds it on the metal tab and it slipped right off. I didn't even have to pull it apart - just untaped the bundles, clipped the offending wires free of the connector, stripped and reconnected them with a butt connector.
Thanks to everyone who contributed to this thread! I appreciate the help.
Old 12 Oct 2011, 04:28 pm
Glad to hear my easy fix worked for ya!
Old 07 Oct 2013, 11:03 am
Same problem. 2005 Cruiser. I don't see a pink/black wire. Maybe I just need better detail. Help?
Old 07 Oct 2013, 11:54 am
...as was quoted, "under and behind the fuse box" or as the other poster said, "behind the kick panel on the left side on the lower left of the steering wheel"....which is where the fuse box is on the earlier models.
Old 07 Oct 2013, 12:21 pm
I feel lik a rookie on the bomb squad. Too many wires. Too many boxes. Any guudance helping me find the right one? Any way to override and close power windows
Front power windows no longer working...? whitbyPT Interior Accessories Forum 59 19 Jul 2016 05:50 pm
Pwr Windows/Blower Fan/Back-up lights/Rear Window Defogger/Air Bag Light elgeeps Tech & Performance Forum 12 20 Oct 2014 10:19 am
Rear and Front Fog Lights not working-Help! backtorealityuk Tech & Performance Forum 1 20 Dec 2010 03:50 pm
Lost Reverse Lights & Reverse Shift Bell wunderbluegt General Turbo Discussions 1 06 Jul 2004 10:12 pm
