break light switch/ electrical problems
Old 25 Apr 2011, 03:35 pm
mattsptgt's Avatar
Default break light switch/ electrical problems
My car threw this code any one know where this switch h is located and what causes these to go out
Old 25 Apr 2011, 04:28 pm
Default Re: break light switch/ electrical problems
What is the code? Usually the switch is at some point where it can be contacted by the brake pedal armature. I have seen them break on other cars, they get kicked sometimes, had my clutch one go on a car .... couldn't start it cause the switch was broken .... all in same area.
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 25 Apr 2011, 04:52 pm
SilverSport is correct. The brake switch is right above the brake pedal.
Electrical Problems Nippur General PT Cruiser Discussions 2 29 Jul 2010 05:24 pm
HELP!!! How do you remove electrical connection from oil press. switch??? 66CUDA Tech & Performance Forum 4 15 Nov 2009 07:55 pm
PT Electrical Problems DDPTman Tech & Performance Forum 1 17 Feb 2009 03:34 pm
Electrical problems? Help please. cupcake Tech & Performance Forum 6 24 Jan 2009 04:49 pm
Electrical Problems sdalley Tech & Performance Forum 3 08 Nov 2008 06:20 pm
