Has this gone bad?
Old 27 Apr 2011, 06:26 am
Default Has this gone bad?
Please take a look at these pictures. Has that part gone bad? Is that part of the control arm? The reason I ask is because if you hit your brakes going down hill there is a loud rattling sound coming from the front left wheel area. I checked and nothing seems loose but I wasn't too sure about the part in the picture. Is it just from being jacked up? Thanks.
Old 27 Apr 2011, 06:56 am
Default Re: Has this gone bad?
Looks like the bushing is worn away. Check to see what the other side looks like.
Old 27 Apr 2011, 07:01 am
Yep everybody ,sooner or later, need to replace those bushings...You can replace the whole control arm assembly with a better one, from Moog for about $80 each or you can just replace the bushings with polyurethane, like I did...Just check my gallery
Old 27 Apr 2011, 10:51 am
Does anyone here know of a company that makes and sells performance products for the PT and GT Cruiser for all performance areas of the car.
Sorry to keep going back to the VW, but there are many retailers selling OEM and performance parts and upgrades for all performance related areas of the VW and Audi, including Engine, Tranny, LSD's, Drive Shafts, Turbo Kits, SuperCharger Kits, Programming, Exhuast Systems, Stage 1 - 3 Motor Mounts and Flywheel Clutch kits, Suspension upgrades ... as well as all the dress it up and make it pretty parts and kits .... which is almost all I find for the PT. Anyone selling the Lower Control arm with Poly bushings already installed like I can get for my VW here SUSPENSION
Heck, the poly bushing install is the hardest part of the job!
12 Regal Turbo
06 PT - Base with BLING! TRADED 5/27/13
01 PT LE - Kid's Car - TRADED 01/13
01 Beetle Sport - SilverSport - 150+ MPH
93 Del Sol - 32+ MPG
90 F150
73 Mach1
Old 01 May 2011, 12:12 pm
Update: We were driving in the Laurel Highlands and had to ride down some very steep hills. After getting to the bottom, the left wheel's brake pads were smokin and brake dust was everywhere. The right side is fine. Do you think this has something to do with my problem?
Old 01 May 2011, 12:28 pm
If you take your photo, increase it's size, tweak your brightness and contrast, use an unsharp mask, then tweak your color saturation, then finally reverse the image you can see things more clearly like cracks, tears, splits, etc.
Your image was a pretty low pixel count but here's what it looks like just before reversing the image:
And afterwards, you can tell it's time to replace that bushing!
As to your brake problems, not sure, would have to have a look.
Old 01 May 2011, 01:16 pm
Sorry about the low res pic, i just cropped from the other one and blew it up. But thanks, it looks like its not too bad a fix what do you think? I see the bushings aren't expensive either. Ill whip out the Chilton and see what I'm in for.
Old 01 May 2011, 11:56 pm
You're probably going to need to soak the daylights out of that bolt, looks like it's never been pulled.
Old 16 May 2011, 05:32 pm
I want to try to replace the bushing myself but my chilton manual only has directions to replace the whole control arm. Is all you have to do is take that bolt off and pop out the bushing? That sounds too good to be true...
Old 16 May 2011, 07:36 pm
First you have to remove them from the car, then if you are going with Energy Suspension bushings, you can burn the old ones with a torch and put the new ones...but you you what OEM style bushings you will need to press them.
Watch this video:
