Need some help
Old 05 May 2011, 11:18 pm
03TibbyGuy's Avatar
Default Need some help
So I just drove my pt cruiser from Phoenix to my house which is about 80 miles. It ran fine all the way home but right when I got home and started to pull in the yard it died. When I try to start it, it just doesn't work. It sounds like it's trying to start. The radio works, lights, everything else and theres no clicking like it's the battery. The check engine light is on and the oil light is on too. So I thought maybe I had an oil leak and it ran out but I checked the oil and it's only like a quart low....any ideas?
Just trying to figure it out myself before I have it towed..
Old 05 May 2011, 11:32 pm
Default Re: Need some help
Need to do the 'key dance' and find out what codes it's throwing. Search the forums for it as I'm too tired to try and explain it right now.....sorry....
Old 05 May 2011, 11:36 pm
03TibbyGuy,
Check for error codes using the manual error retrieval method of "key on-off-on-off- and back on" within five seconds. The error code will be display on the odometer. This may at least give you a starting point for where to start looking. Any other details you can provide may help; year, turbo or non, etc.
Last edited by mojoflattop; 05 May 2011 at 11:38 pm. Reason: missed telling him this must be done within five seconds, critical to know
Old 05 May 2011, 11:42 pm
03TibbyGuy's Avatar
Did the key dance and it popped up and said "done". So it's not throwing me any codes.
It is a 2003 non turbo touring edition
Old 05 May 2011, 11:45 pm
damn... remove the negative lead from your battery for 5 minutes, while it's off step on your brake pedal a couple of times to bleed off any residual. After reconnecting see if you can get it to start. There is a post somewhere here of this same exact problem and I'm so tired my brain isn't functioning clearly. You might try at PTCrew.com also, where the other PT wackos hang out.
Old 05 May 2011, 11:48 pm
WolfmanG's Avatar
check your tire pressure and your gas cap, make sure it's all good. then i would suggest disconnecting the battery for about 5-10 min's then reconnect it. then see if you can start her up. what ever happens if the check engine light comes back on, do the key dance again and see if anything comes up.
-Danny Wolfman G
Old 05 May 2011, 11:52 pm
03TibbyGuy's Avatar
Thanks guys I'll check it out right now
Old 06 May 2011, 12:02 am
03TibbyGuy's Avatar
K waiting 10 minutes now..
It's just weird cause it drove fine all the way home and then out of no where it just died and won't start back up..
Old 06 May 2011, 12:05 am
03TibbyGuy's Avatar
Sorry I just realized I put it was a limited edition. It's actually a touring edition, not sure if it matters lol. I'm a little tired myself
WolfmanG's Avatar
yeah i think there's was someone else who went through that too a few months ago. cant remember who it was tho.
-Danny Wolfman G
