Need some Help - parking lights are staying on
Old 14 May 2011, 10:34 pm
Default Need some Help - parking lights are staying on
I have a 2006 PT and I have had some problems lately with my battery. I just put a new battery in it today and the parking lights and lights in the center of the dashboard stay on after I turn off my lights. I had to pull the fuse to keep my battery from dying again. The fuse controls the parking lights, center dash lights, power locks and alarm. What could cause this? Has this been brought up here before as an issue?
Any help would be great!
Old 14 May 2011, 11:07 pm
Default Re: Need some Help - parking lights are staying on
Do you have the keyless entry system? May have SKIM issues if so. It's got a program for how long to allow the lights to stay on when you exit the car. Once in a blue moon the SKIM will freak out and hang that way.
I would suggest removing the positive lead off the battery for 5 minutes, while it's off, press on the brakes a couple times just to make sure no residual charge is on the system. Turn on everything while the battery is disconnected, I mean everything. Then turn it all back off before reconnecting.
I don't know why but this sometimes clears up these odd faults. If the SKIM is still buggered, then I'd have to delve deeper to try any other suggestions. Mind you, this is all assuming you have keyless entry.
Old 14 May 2011, 11:21 pm
Yes I have keyless entry. I'll give that a try. The battery light keeps going off and on too.
Thanks for the help!
Old 15 May 2011, 12:08 pm
Most of the time that this happens it is caused by the multifunction switch is going bad. Only fix is either a rebuild or a new one.
Old 15 May 2011, 03:58 pm
Good point Hooligan. My MFS problems were the opposite, but I could see how it could cause this. That thing is so buggered up I should have bought an extra for the next time it fails...
trac control & abs light staying on in dash bobs turbo pt General PT Cruiser Discussions 13 22 Apr 2017 08:44 am
Parking the car - Which gear? dom92 General PT Cruiser Discussions 14 03 Mar 2011 08:49 pm
parking brake stevas Tech & Performance Forum 1 04 Jan 2011 11:47 am
Parking sensor macca325 General PT Cruiser Discussions 4 13 Jun 2008 09:57 pm
