Ignition Issue !!, Fuel pump, filter or MAP sensor?
Old 17 May 2011, 05:51 pm
Question Ignition Issue !!, Fuel pump, filter or MAP sensor?
Hi, I just purchased of a Limited Edition 2002 with 175k miles !!!! I know...I'm fixing things here and there..
So the problem started with the fuel pump, it was pretty much dead, I purchased only the replacement electrical motor with the filter, and worked fine, until some days ago where it started to fault as if not enough fuel was being pumped, I pressed the fuel valve and seemed a lot of pressure there,
I've change the sparks and some burned fuses.
Somebody told me that it could be the MAP sensor, I really dont know where to start, since the problem comes and goes.
Old 17 May 2011, 06:04 pm
Default Re: Ignition Issue !!, Fuel pump, filter or MAP sensor?
How could it have been working "fine" with a few blown fuses?
You say you changed the sparks which I take it means spark plugs but what about the wires, they wear out too?
It seems like a lot of pressure, but you'll never know without testing it. 15 lbs of pressure seems a lot but if you need about 45 lbs it won't work right.
You replaced the pump motor and filter but it's always a good idea to flush out the injectors when messing with the pump. It takes very little debris to clog one or two of them up.
Go for the MAP sensor last unless your getting a fault code (P0105, 106, 107 or 108)
Are you getting the engine light that says there's a fault somewhere ?
Old 17 May 2011, 06:22 pm
Smile Re: Ignition Issue !!, Fuel pump, filter or MAP sensor?
I know, I'm not sure how it it worked with so many fuses blown out,
Actually when I just bought it smelled like burned plastic, unplugge dth ebattery and started looking for any burn fuses, and found one!!, 10A red fuse within the interior fuse box, replaced it and everything went back to normal.
Yes, I meant the spark plugs, Did not test the wires (don't know how), as well as the pressure I wouldn't know how to test that. Also did not flushed the injectors (is there any ways I can do that?).,
The feeling when it starts failing goes as follows; start the car and if uphill (manual transmission) Right form the beginning feels as if I need to keep on giving gas, (pressing the pedal on a repetitive mode) to have it go, If I don't do this the car simply doesn't "have enough power" once I reach second gear ( I usually switch at 2100-2500RPM) and the car has speed then everything is normal,
I know it has something to do with some of these reasons
Old 17 May 2011, 06:40 pm
Without the proper equipment and manuals, testing isn't your option. Since you didn't know the history of the car, wires should have been done with the plugs. Easy enough to do now.
Fuel pressure; here's something to read but you might want to have that done professionally along with a forced injector cleaning.
How To Check Fuel Pressure On A Pt Cruiser - Page (1) - Doocu.com
Tags
fuel filter, fuel pump, map sensor
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
crankshaft position sensor, fuel pump??? HELP!!!! Amy Tech & Performance Forum 10 23 Jan 2011 07:30 am
Bad Fuel Pump/Filter or what? onedivinehammer General Turbo Discussions 11 09 Aug 2010 10:11 pm
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
