Tail Lights Not Working
Old 24 May 2011, 08:09 am
Sue Sue is offline
Default Tail Lights Not Working
All tail lights work except the Tail light when I turn on the headlights. Even the Hazard Warning operates the bulb for the tail light. Is there a fuse issue?
Rich
Old 24 May 2011, 08:33 am
Excoastie's Avatar
Default Re: Tail Lights Not Working
you're not real clear on your issue here.... correct me if I'm misunderstanding what you're asking...
You're saying that your turn signal lights work, as do your brake lights, but when you turn on your headlights you get nothing to work at all.....?????
If this is the case it does indeed sound like some sort of fuse issue. I'm not an expert on the PTs (they'll come along shortly), though I have done some tinkering on various vehicles throughout the years. When something electrical doesn't work, the first thing I check is the fuses.
good luck
Exco
I tend to ramble and repeat myself, please try to over look my ignorance.
Bill
Old 24 May 2011, 09:52 am
RaineMan's Avatar
I believe she means the tail lights work and the turn signals work but the brake lights do not.
First thing, replace the bulbs. Those bulbs are dual filament (one for dim and one for bright) and the bright filament may just be burned out. If that doesn't fix things start checking fuses.
Old 24 May 2011, 10:25 am
Sue, It also helps to tell us what year your car is. There's major differences between the 01-05 and the 06+ cruisers especially the electrical side. Follow the advice given above and let us know what you find.
The 01-05 has two fuse boxes so check both if you fall into that category.
Old 24 May 2011, 12:52 pm
fuse or MFS...
Old 26 May 2011, 06:03 pm
WolfmanG's Avatar
the red arrow is pointing to the turn signal/hazard. The green arrow is pointing to the brake light, which one is it?
-Danny Wolfman G
Old 27 May 2011, 11:00 am
Sounds like it's the fuse
Bubble Mailers Wholesale
my door locks,head lights and tail lights don't work. bones02 Tech & Performance Forum 38 06 Apr 2016 10:30 am
Head Lights and Tail lights not working. 1morgana General PT Cruiser Discussions 6 15 Nov 2014 12:38 am
HELP! '02 Cruiser with no tail lights, then no brake lights. tschauer Tech & Performance Forum 1 16 Sep 2010 05:54 am
Smoked tail lights and reverse lights! chris15 Exterior Accessories Forum 15 01 Jun 2010 05:53 pm
Why do my tail lights and dashboard lights only go on when I brake? bodykits Exterior Accessories Forum 1 16 May 2009 07:28 am
