Rubber windshield gasket?
Old 25 May 2011, 04:54 am
Question Rubber windshield gasket?
It looks like the previous owner had the windshield replaced and the paint got nicked. There is some rust under the rubber gasket that surrounds the windshield.
Is this rubber gasket easy to remove and reinstall?
I'd like to fix this before it becomes a big problem.
Old 27 May 2011, 08:07 pm
Default Re: Rubber windshield gasket?
*Bump*
...nobody has any experience dealing with the windshield?
Old 27 May 2011, 09:43 pm
Might want to ask over at PTCrew.com. I've never had the PT's windshield out, each manufacturer does it a different way so even though I've had others out I wouldn't want to mislead you on this one.
I just read through the OEM service manual and the instructions are way different from what I'm used to. You actually have to cut the urethane from around the window to remove it. I haven't read more, but will PM you with some info.
Old 27 May 2011, 10:05 pm
Not looking to remove the glass. I just want to remove the rubber gasket around the windshield to get at the metal underneath... Really only about 10" worth.
I'll have to dig through the service manuals and see what they say.
Thanks!
Tags
gasket, windshield, windshield gasket
SUNROOF RUBBER GASKET, NEED GOOD PROTECTANT clevelandmike The Detail Shop 14 11 Mar 2015 10:38 pm
Help with windshield blades leaving rubber marks avaldez Tech & Performance Forum 7 13 Feb 2011 03:32 am
Rubber... garner49 General PT Cruiser Discussions 2 22 Jul 2009 07:54 pm
cowl rubber in or out. amx1397 Turbo Performance 18 29 Mar 2004 12:36 am
feeler: 18" with rubber... COP TZER Canada PT Forum 0 01 Oct 2003 12:54 am
