what kind of screw?
Old 27 May 2011, 02:43 pm
Default what kind of screw?
Folks - there's something hanging down under my PT, and it drags on the ground. I'm fairly sure it's the engine splash shield. I lifted it up and it's just missing a screw, but I've been through every screw I own and can't find one thick enough. I was going to head to Kragen/autozone to look, but no idea what size I should be looking for?
Does anyone know? Anyone with a service book that might list it??
Greatly appreciate any help!!!
thanks,
Matt
Old 27 May 2011, 03:07 pm
cruserdad1976's Avatar
Default Re: what kind of screw?
I put a big zip tie in mine and it has worked for over a year
Old 27 May 2011, 03:47 pm
Mine's zip tied also.
Old 27 May 2011, 07:03 pm
not sure i follow, it's hanging down from the back (not the part that tucks under the fender) - it's just a single screw hole - how'd you manipulate a zip tie to work there?
Old 27 May 2011, 07:15 pm
Been awhile since I had to tie it but there must be something I used to go through the hole and come around to close the loop.
Old 27 May 2011, 09:49 pm
It's actually held with a plastic body panel plug. I just bought several packages as the guys who did my bodywork after my wreck didn't reconnect it all. I think the hole is the size of a pencil, so I went into Advance Auto and found a box of 4 plugs for Ford, they fit perfectly.
Old 28 May 2011, 07:46 pm
nice! that did it! thanks v. much! I have 2 PT's - didn't know why it didn't occur to me to look underneath the other one till now, but you're absolutely right, it's a large plastic plug, not a screw.
For future reference (or should the zip-tie guys want to go this route) I went to Autozone and got the "Dorman 963-060" pack for $2.50 - which contains 4x Chrylser/Ford plastic panel retainers. There's two that have screw type threads that were too small, and 2 that are V shaped. The V shaped one went in snug, and I have it a few good hard yanks, and that sucker's not going anywhere.
thanks again!
-Matt
Screw turns, but won't come out...? paramo Tech & Performance Forum 6 19 Apr 2011 11:54 am
SCREW SIZES BKLYNMATT Interior Accessories Forum 1 30 Aug 2010 08:45 am
Did I screw up? stu88 Tech & Performance Forum 1 31 Jan 2010 03:03 pm
Is Chrysler trying to screw me? biggus127 General PT Cruiser Discussions 8 30 Aug 2007 07:23 am
Plug & Wire Change Screw Up???? BB Turbo Performance 12 24 Feb 2007 12:15 am
