2002 Engine blown
Old 31 May 2011, 06:36 am
Default 2002 Engine blown
My wife's 2002 Pt blew the engine. It has 155,000 on it. I want to replace it but need some advie.
I began searching for an engine and was told that only the 2001 and 2002 would fit. If I was to do a complete engine, Tranny and axle swap, could I go to a newer Year?
I haven't found too many 2001/2002 engines and would like to expand the search.
Are there any good places to search?
Old 31 May 2011, 02:29 pm
cruserdad1976's Avatar
Default Re: 2002 Engine blown
there are a few thing that arew diffrent i think it is the location of some sensors and it makes changing years a pain it can be done but may require a diffrent wiring harness
Old 31 May 2011, 08:02 pm
Dino's Avatar
Quick search on ebay.
01 02 PT Cruiser Engine 2.4L Motor VIN B 84K LKQ | eBay
Old 01 Jun 2011, 08:35 am
A newer year wont work. The biggest problem is the crankshaft has a different number of teeth on the tone wheel for the crank sensor. The cam magnet and sensor is different also. They did this along with changing the engine controllers. So you would need a complete wiring harness and PCM and weather a used PCM would work with your SKIM module (if equipped) or not, who knows. Find an 01 or 02 or have yours rebuilt.
Old 01 Jun 2011, 10:35 am
how bad did it blow????? if it just spun a bearing or if a ring broke or some thing other than a piston sticking out the side of a block id just get it rebuilt do you have a Jasper Engin Rebuilderrs in your area
Old 01 Jun 2011, 11:36 am
I've seen a guy putting a 07 engine on a 03 and I've seen another put a 95 Stratus engine on a 02 Pt cruiser....but never seen and 03 and up on a 01-02
You should ask this question on ptcrew.com...those guys should now
BTW here is a link of the 03 with 07 engine....You'll need to sign up to ptcrew in order to see it.
PTCrew.com - Learn it or Burn it.
2002 2.4 engine bad matt82 Tech & Performance Forum 3 03 May 2011 08:57 am
2002 need engine 2.4 jakiept General PT Cruiser Discussions 0 24 Sep 2010 02:23 pm
2002 Engine Shutoff? j_desan General PT Cruiser Discussions 5 25 Mar 2010 08:07 am
2002 Engine Non-Turbo driveability Classifieds: Want To Buy 0 08 Feb 2010 09:27 am
Blown up engine dman762000 Tech & Performance Forum 4 07 Apr 2008 11:24 pm
