Tension bolt
Old 01 Jun 2011, 02:46 pm
Angry Tension bolt
Does any one know what size the tension bolt is on 2007 2.4.L mine is gone fell out need one my belt is squeeling need to tighten up the belt.?
Old 02 Jun 2011, 06:53 pm
Default Re: Tension bolt
Well, you're probably getting no replies because it's very hard to be a mind reader, and/or to guess which bolt you are speaking of. Can you get more specific, maybe even provide a photo???
Old 02 Jun 2011, 07:04 pm
Okay, if you're talking about the bolt on the belt tensioner, then here it is below. I pulled the parts catalog for 2007 2.4l and found that it's an M10 X 1.5. See snip below from the parts catalog.
Which bolt is the tensioner bolt on the alternator? bjagd02 General PT Cruiser Discussions 6 23 May 2010 10:57 pm
cut off bolt for control arm richwms1 Tech & Performance Forum 10 10 Dec 2009 08:19 pm
oil pan bolt demon666 Tech & Performance Forum 8 22 Jul 2009 12:32 pm
EGR valve, 1 bolt?! DIYPTGUY Tech & Performance Forum 4 20 Feb 2009 08:55 pm
