Fuel Filter / Pump issue ???
Old 16 Jun 2011, 08:45 pm
Location: Centralia, Washington ( dead center between Seattle + Portland )
Default Fuel Filter / Pump issue ???
I need some help - car died while driving . ( choked out ) started up a few times ... ran smooth . pushed on gas ... was fine ... put in gear - moved about 5 feet- choked out. Rinse + repeated about 5 times . each time it died after moving 5 feet. Now it wont start at all ... but it does turn over . I am thinking Fuel filter or maybe pump ?
Is there a way of testing those to see if its bad ?
- I have a '01
and its my Baby !
Old 16 Jun 2011, 09:49 pm
Default Re: Fuel Filter / Pump issue ???
How many miles? Filter & pump are both contained in the gas tank, very seldom happens!!!
Old 16 Jun 2011, 09:52 pm
SCBluePT's Avatar
Was the car low on gas when this happened?Since the fuel pump is cooled by the fuel around it,running low on fuel could cause the pump to go bad.
Old 16 Jun 2011, 10:04 pm
ok - so miles are about 145k
The tank was just under 1/2 full
I just figured out how to do the # test thing run*off*run*off*run
P 0340 = Camshaft Pos. Sensor
P 0645 = A/C Clutch relay control circuit
P 0320 = ignition / distributor engine speed input
P 1391 = intermittent loss of CMP or CKP
P 1193 = Inlet air temp. circuit high
Dunno what any of that means =) but thanks to google i found that at least
any help/input - appreciated
Old 17 Jun 2011, 12:17 am
01 PT with cam/crank code problems
ok so digging around some more i found this .. and going to give it a try in the morning ...
Old 17 Jun 2011, 12:36 am
just for S n G's i ran outside and pulled the neg cable on battery.... replaced -
and now only P 1684 and P 0320 show up....
dunno why those others went off before /shrug ...
anyways ... the 1684 is just bat unplugged within last 50 starts or something. ... but the 0320 still sucks.
think it might narrow down my prob tho.
Old 17 Jun 2011, 12:58 am
P0320 Chrysler DTC: No Crank Reference Signal to PCM Conditions
found that =( sounds ugly
Old 17 Jun 2011, 01:12 am
Cam sensor
Crank sensor
Does this look right ? Trying to narrow down what I can to help myself ... just lookin for more imput before I start buying anything or take to the dealer =(
Old 17 Jun 2011, 06:16 am
In 2004 the crank sensor was moved (to make it harder to get to ) to the area in back of the starter which is in front of the engine if your standing in front of the car.
Old 17 Jun 2011, 06:44 am
Dill's Avatar
Have you tried bleeding the fuel lines of air and trying to start the car with pedal to the floor until it starts and gets to like 5k rpms?
Worked for me but my issue may be totally different!
fuel pump, fuel filter or o2 sensor? Joey Tech & Performance Forum 12 02 Apr 2013 07:51 pm
Ignition Issue !!, Fuel pump, filter or MAP sensor? somarillw General PT Cruiser Discussions 3 17 May 2011 06:40 pm
Bad Fuel Pump/Filter or what? onedivinehammer General Turbo Discussions 11 09 Aug 2010 10:11 pm
Issue With my 2001 PT Air Filter/Fuel Filter/Tranny Rekoj Tech & Performance Forum 7 10 Jul 2009 12:27 am
2002 PT (in tank) Fuel Pump/ Fuel Sender cruiserich Classifieds: For Sale/Trade 0 27 Jan 2009 06:08 pm
