Pt Cruiser vert.TRANS leak
Old 20 Jun 2011, 05:39 pm
Default Pt Cruiser vert.TRANS leak
After I got this pt I seen a red oil spot on the drive. Took it back to the dealer and they said: I had signed the AS IS paper. Looks like it is the solenoid pack. 300.00 for parts and 300.00 to do the job. I just had a friend look at it and when he took the air cleaner out of the engine area the vent hose that hooks up to the air box was just hanging. The air box has oil in the bottom of the air box, and that I will take out and clean with simple green let air dry and put back together. I think I found the problem with a friends help. Knock on wood......... for me please! Hope this works xtreme cindy
The line that go's to the air box needs to be replaced. It is cracked at the end and won't stay on the box. The red oil is true it leaks, but he found why. The line that hooks to the trans the pinch clamp was not holding it tight on the fitting. He put a screw clamp on and it looks like he found the problem. I'm so sorry I did not have all the facts right. But the dealer should have seen that and they just wanted to sell me the bigger job and that would have not fixed it at all because the solenoid pack is not even where the hose is. I seen this so I do know now. Sorry xtreme booboo
Old 20 Jun 2011, 05:52 pm
Default Re: Pt Cruiser vert.TRANS leak
Cindy, I may be wrong but the oil in the air box is normal and is black and if your dripping red, than it's not the same oil. Maybe someone will confirm this. The solenoid does leak and can be replaced. I think we even have instructions in the HOW TO section. Not that bad of a job and you can save a bunch of money.
Old 20 Jun 2011, 06:50 pm
WolfmanG's Avatar
honestly i don't know where or what the solenoid pack does or is, but if it has anything to do with the transmission then that would explain the "red oil" right?
-Danny Wolfman G
Old 20 Jun 2011, 09:57 pm
mdfrodolives's Avatar
There's a "How To" on the solenoid pack replacement in the Mod Bible in the PTCrew (forum). I can't remember this last ... PTCrew something or other. Crewzin knows for sure.
Anyway, Cindy, you can buy the automatic solenoid pack at RockAuto.com for half the dealer's price--and it's Borg Warner ... a good brand in the industry. If you read the How To and feel like doing the job yourself, then go for it. Maybe a friend who does wrenching can assist you.
Because ... that red oil is definitely automatic transmission oil. And our PT's most often leak at the solenoid pack (cause the OEM one works quite well, but is prone to leaking at the seal and also at other integral plastic areas).
Look up as much as you can about instructions. In the meantime, check your auto trans oil level. Do it per your Owner's Manual instructions. If you have to add oil, use only ATF+4--and nothing else. And add a little at a time. You don't want to overfill.
There have been many discussions on this leaky part on this forum. Do a search on the automatic transmission solenoid and see what's what.
Tim
Old 21 Jun 2011, 05:26 am
Old 21 Jun 2011, 06:07 am
At least the problem was found and all looks well now. hopefully the whole experience will help someone else with the same kind of problem.
Old 21 Jun 2011, 06:44 am
Your so right Crewzin. Thanks for all your help. xtreme
2007 Cruiser with 33,719 miles on....already has an oil leak??? xxcutetaraxx General PT Cruiser Discussions 11 26 Mar 2011 08:32 am
Diesel PT Cruiser Water Leak! Tech Tech & Performance Forum 3 06 Nov 2010 11:23 am
New 2006 PT Cruiser GT Vert owner here...... PA_NC_Cruiser General PT Cruiser Discussions 11 06 Apr 2010 09:51 pm
A beautiful Vert........dream Cruiser 4...2005 careyk PT Cruiser Convertible Forum 1 04 Feb 2009 07:55 am
2002 pt cruiser 5spd trans when to get used bobby515 Tech & Performance Forum 1 26 May 2008 07:39 pm
